Look Van Turbo
Old Mar 19, 2008 | 09:06 AM
03_PSD's Avatar
03_PSD
Look Van Turbo
http://cgi.ebay.com/ebaymotors/7-3-P...spagenameZWDVW
Old Mar 19, 2008 | 11:08 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Did you get it Glenn? It looks to be in good condition.
Old Mar 19, 2008 | 11:11 AM
That_Guy's Avatar
That_Guy
SHHHH!!!!! you wernt suposed to tell anyone I was looking at getting that....Now more people will be bidding lol.
Old Mar 19, 2008 | 11:19 AM
03_PSD's Avatar
03_PSD
I wish man, would be nice.
Old Mar 19, 2008 | 11:22 AM
03_PSD's Avatar
03_PSD
would you have to have custom tunes and bigger sticks to make that work good on a truck or would it be ok as is
Old Mar 19, 2008 | 11:26 AM
That_Guy's Avatar
That_Guy
I think the custom tunes help with the lag since its flows more air, and you can run stock sticks from what Ive been told.
Old Mar 19, 2008 | 11:31 AM
Mike F250's Avatar
Mike F250
Why wouldn't the van turbo be the same as the truck turbo? Just trying to learn/understand...
Old Mar 19, 2008 | 11:32 AM
03_PSD's Avatar
03_PSD
what is the max boost you can see with the van turbo
Old Mar 19, 2008 | 11:36 AM
That_Guy's Avatar
That_Guy
The housings are bigger to keep the EGT's down since the vans didnt come with intercoolers
Izzy351's Avatar
Izzy351
It has the same "mechanics", but different exhaust housing (1.15 AR) because the vans don't have an intercooler or wastegate. It was designed for that application, but is a bit of an upgrade to our trucks because it can handle higher boost numbers (30-35psi, IIRC).
Old Mar 19, 2008 | 11:41 AM
03_PSD's Avatar
03_PSD
so, what else do you have to buy to adapt it to our trucks. the up-pipe
Old Mar 19, 2008 | 12:17 PM
Tenn01PSD350's Avatar
Tenn01PSD350
It seems to have pretty much all you need. It also looks like it has a 1.0 housing. I saw a blank pedestal and the unit looks like it is going to be non wastegated and non EBV setup.
Old Mar 19, 2008 | 12:44 PM
Izzy351's Avatar
Izzy351
It bolts right in place, but I think you have to do something on the outlet. Like get a non-ebpv outlet to bolt on. The stock ebpv outlet will not bolt up, but I read somewhere that you can have it welded on if you really want to keep it (I think it was Brandon's -- bdrummonds thread). I didn't look at the ad, so I don't know what it comes with. Mike says it has all you need, so you'll probably be in good shape...
Old Mar 19, 2008 | 12:55 PM
Tenn01PSD350
I would ask him what size the exhaust flange is just to be sure it will fit. Here is what it looks like Joe, it also comes with a non-EBV pedestal.
Old Mar 19, 2008 | 12:59 PM
Tenn01PSD350
This may answer a few questions before they are asked. The center unit is what I am currently running.
