Weird Motor Issues
Old Mar 18, 2008 | 09:30 PM
prernrgod's Avatar
prernrgod
Weird Motor Issues
Background Story---1996 F-350 156,000 miles, 5 speed, 3.5 level kit, 35"tall tires. Intake, Exhaust, gauges, and Edge programmer (I know edge sucks !!). Issue started last Saturday. Start truck, let idle for 2-3 minutes, take off and 100 yards later it loses power, check engine light comes on, and runs like crap. I shut off, restart, and then drive home fine. Yesterday on the way home it does the same thing. This time it doesn't go away. I limp it home (about 2 miles) and notice the EGT gauge is showing only 150-200. (sensor mounted on drivers side exhaust manifold). I think thats weird but dont think to much about it. I get home and remove the program and put back to stock. I check codes and it says Exhaust Pressure Sensor Fail. Today I replace with new Ford sensor. Didn't help. Now throw code IAT intermittent high voltage. Now I notice that after letting it "run" for 30 seconds, the drivers exhaust manifold is cold to the touch and the passenger side is warm. Now I am totally at a loss of what to look for. Does anyone have any guesses?? Thanks in advance
Old Mar 18, 2008 | 09:33 PM
tjbeggs's Avatar
tjbeggs
you probably have an injector harness that has gone bad. Check both valve cover connectors for melted plastic also read this thread to check the harness inside the valve cover
https://www.ford-trucks.com/forums/6...=1#post5286089
Old Mar 18, 2008 | 09:41 PM
MADVAN's Avatar
MADVAN
Iam with Tj.
Also ignore the IAT. It does nothing in a PSD.
Bill
bigbadwolfe's Avatar
bigbadwolfe
could be the I.D.M. as well when my idm went bad it only ran on 4 cyls
Old Mar 18, 2008 | 09:43 PM
tjbeggs's Avatar
tjbeggs
It could be but most times the IDM goes into survival mode when a UVC goes out and shuts down the whole bank so it doesn't get burned up.
Old Mar 18, 2008 | 09:51 PM
MADVAN's Avatar
MADVAN
Originally Posted by tjbeggs
survival mode
Thats a new term!!!
I like it!
Bill
73FOMO
Feb 2, 2014 11:20 PM
Feonix1123
65
Apr 28, 2013 09:39 PM
agg_bagg
Aug 3, 2011 10:36 AM
1duallyman
Jan 3, 2011 10:21 AM
Shake-N-Bake
28
Mar 7, 2010 10:19 PM
