96 shorty stalls and won't restart.
Sounds like fuel
Originally Posted by savagefan
Hi my boy's star will run for 15 mins , stall and not restart for 30-40 mins. Sounds like an ignition module to me, are there other possibilities? And does the 96 have a distributor ignition? I can't get out to see it till the weekend. Thanx.
Fuel system might be restricted or fuel pressure reg problem. Have you changed clogged fuel filter also check your air filter ? next check would be fuel rail pressure check.There is a shrader valve on the fuel rail on the left side near the front of the engine, (35-40 psi is normal). Also engine fuel mixture is controlled -partly by ECT ( Engine Coolant Temp sensor) this serves to enrichen the fuel/air ratio as needed depending on engine temp. Also clean your MAF meter.
This engine is OBD2 compliant & is possible to rig up a full digital dash with the right software /scan tool. This is very helpful for trouble shooting as ALL sensors can be monitored. Shame a fuel pressure sensor was not included in the sytem, but it is quite feasible to add one or rig up a pressure gauge for checking.
Aeroman.
madscientist
Modular V8 (4.6L, 5.4L)
07-09-2021 10:45 AM
sniperscoutwill
02-18-2016 09:56 PM
madscientist
1999 to 2016 Super Duty
06-08-2015 07:56 AM
bigblockcrewcab
12-22-2010 10:50 AM
