t444e vs powerstroke
Old Mar 18, 2008 | 04:31 PM
secondarychaos's Avatar
secondarychaos
Is there any difference between the t444e and PSD motors?
Specifically, because the t444e is built for bigger rigs, is it also stronger?
Im thinking, if it is, that it would be better suited for a performance build up. any input appreciated
Dan
Old Mar 18, 2008 | 05:07 PM
powerstrokeddiesel's Avatar
powerstrokeddiesel
i am curious to see the results on this one to... i have been wondering is the t444e stronger???
Old Mar 18, 2008 | 05:15 PM
superduty4x4's Avatar
superduty4x4
As far as I know they are identical. Where is tjbeggs?
Old Mar 18, 2008 | 06:13 PM
IDMooseMan's Avatar
IDMooseMan
Ditto and ditto.
TJ? Neal? Joe? You guys busy?
Old Mar 18, 2008 | 06:42 PM
tjbeggs's Avatar
tjbeggs
The T444E and the PSD are the same exact thing as far as the long block goes. Some have same injectors some don't. Some have the same turbo some don't.
Old Mar 18, 2008 | 06:52 PM
powerstrokeddiesel
umm how many cc injectors do some of them have??? and what size turbo???
Old Mar 18, 2008 | 06:56 PM
Todd525's Avatar
Todd525
I thought that they had the bigger inje3ctors, and different programming. I remember someone was looking into a set of injectors to put into their powerstroke for the extra UMPH.....wink wink............
Old Mar 18, 2008 | 07:01 PM
tjbeggs's Avatar
tjbeggs
Turbo not sure. I have only heard of one person who did the switch. It was expensive, nearly the cost of D66 from Beans but the D66 didn't exist then. I don't know any details of it though.
The injectors are AC's and they are the same as a set of stage 1's, around 160cc per 1000 shots.
Old Mar 18, 2008 | 07:21 PM
powerstrokeddiesel
will the injector work in our trucks??? i mean with our programming...
Old Mar 18, 2008 | 07:23 PM
tjbeggs's Avatar
tjbeggs
yes the AC's will work just fine. Just like with stage 1's you won't get all the power out of them unless you have a ship burned for the injectors but they work just fine.
mklemin's Avatar
mklemin
I know this might be stupid or something where do you find the T444E? Does it come in certain OBS trucks or comes in bigger trucks?
Old Mar 18, 2008 | 07:25 PM
powerstrokeddiesel
but the main ??? is umm is the t444e injector more expensive or cheaper then stage 1s???
Old Mar 18, 2008 | 07:26 PM
tjbeggs's Avatar
tjbeggs
Its found in International trucks of the same vintage. Maybe even a few years prior to 94.5 and I am not sure where International stopped using the T444E.
Old Mar 18, 2008 | 07:27 PM
tjbeggs's Avatar
tjbeggs
More expensive. You won't be able to buy a set of AC's for less than you can DIY your current injectors.
Old Mar 18, 2008 | 07:29 PM
powerstrokeddiesel
i am afraid to do it myself tho... i am afraid of tearing up 1 of the injecors... any worries in this???
