RACK and PINION ??s
Old Mar 17, 2008 | 04:04 PM
Voh's Avatar
Voh
RACK and PINION ??s
I am going to install a rack and pinion on my ’64 similar to that as offered by No Limit. Does anyone know of a resource where I could compare widths of rack and pinions vs. what I need to use on my truck? I am planning on pricing it all out / purchasing it separately from the kit (I hope that i can do it for a bit less then $570 or so that it is). PLus their kit is mpower, I would like it remain manual steering. thx<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Mar 17, 2008 | 04:10 PM
85e150's Avatar
85e150
I think you will be hard pressed to find a manual rack and pinion strong enough to work in your truck. A power unit installed w/o power would return a miserable experience as the ratio would be so fast that you would need a 24" bus steering wheel to be able to park or drive a slow speeds.
I think you are in uncharted territory here and I would urge you to reconsider. As pathetic (by current standards) as the original set up MIGHT be, a freshened, WORKING original set up is much preferrable to an unusable custom job. jmo
Old Mar 17, 2008 | 04:37 PM
Voh's Avatar
Voh
If you can put in a MII with manual, wouldn't that work? What about the durango, was that manual?
..The response from No Limit was to connect the supply/return lines. It didnt sound quite right. Maybe the kit price it ok.
Old Mar 17, 2008 | 06:16 PM
gritsngumbo's Avatar
gritsngumbo
Doesn't make any sense. Sounds like they answered a question you didn't ask.
Old Mar 17, 2008 | 08:26 PM
garbz2's Avatar
garbz2
Connecting the lines allows the power rack to be manual with about ten times the steering effort as the old ford recirc ball unit...Its a trick to get you home without blowing fluid everywhere and ruining the rack.
Dakotas had manual racks but are rare..Durango parts do not fit the IC cross member kits.
No limit did the engineering and offers NEW steering arms to correct the bump steer and ackerman. Thats why they offer the rack and pinion as a kit....Something you cant do on your own...
Garbz
Old Mar 17, 2008 | 09:35 PM
Voh's Avatar
Voh
I had asked if it was available with a manual rack...to which they said you could loop it.
Old Mar 17, 2008 | 09:36 PM
Voh's Avatar
Voh
Garbz
THen maybe the price isnt too bad....who knows. THanks again.
Old Mar 18, 2008 | 01:16 PM
garbz2's Avatar
garbz2
Yes, It is not too bad a deal, I am not sold on Rons way of doing it, but he has a shop rig with a bunch of pilot miles on it. He usually will answer any concerns and backs his products.
Garbz
Mgodsy
Dec 9, 2012 01:43 AM
ExcursionAmazon
Jul 22, 2012 12:00 AM
F100BGS
Oct 2, 2011 04:18 PM
