Beefy Safari Rack mounting...HELP!!
Ladies and gentlemen...I am having a big a$$ steel safari rack fabricated for the X...and we are looking at the best ways to affix it to the top. I currently have the roof rack rails (standard w/the X) and nothing more. Called Ford to see if there was some type of bracket that slid into the rails that would hold a roof rack and well...they were not very helpful to say the least...<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
I am looking at more of a permanent mounting system...do not foresee the need to ever take it off. The rack will run the length of the affixed rails and as far towards the front as we can safely get it (maybe another 12 inches at most). <o></o>
<o></o>
I have seen a lot of these mounted on X’s and other SUV’s online…just can not seem to see how they are mounted. <o></o>
<o> </o>
I would greatly appreciate any help from you guys!! Thanks!<o></o>
<o></o>
Anna
<o></o>
<o></o>
<o> </o>
<o></o>
Anna
on
Two only real options that I could think off, and have in my mind my own custom rack one day.
More permanent is to take off all stock pcs from roof, add flat bar to rack, apply a closed cell tape like on canopies, and bolt it right into the roof. Right in the place of stock rails.
Option 2; leave original rails, and remove all cross bars. Unbolt the 2 back end of rails on stock rack. Have shop add flat stock at slight angle so you can slide into the rails, kinda like stock cross bars do now, just full length. Add a few bolt holes to sinch it in place. This way you could remove fairly easily with out much effor, but not quite as strong as bolted to roof.
Good luck.
Good luck.
Oh, and I'm going to be adding a High Lift mount, a shovel mount, maybe some locking storage...
Good Luck and post up pics of what you decide to do.
Awesome!! Thanks for the info! I think I am also going to have a high lift jack mounted to it. Was going to have a mod made for mounting a spare tire on the rack, then someone brought up a very good point, getting the 40 inch spare off a giant X w/a 10 inch lift. DAMN the common sense!
Will keep you posted as the work begins!
Big-Sarge
6.7L Power Stroke Diesel
168
10-28-2022 02:54 PM
