Sponsored by: Real Truck
Poor Idle at Cold Start
Old Mar 17, 2008 | 03:48 AM
texex's Avatar
texex
Unhappy Poor Idle at Cold Start
2000 250,CC,SB,V10, K&N filter, Throttle Body Spacer, 106,000 miles.
I have noticed lately that when starting cold, the engine will not start/idle properly. I have to hold the gas pedal in order to keep running. Sometimes it starts right up, others not. Well, yesterday was the worst, I could not keep it running enough to drive a couple miles down the road. Then suddenly, I hear "something" kick in and it is idling normally. Everything under the hood is tight.
Any ideas? Thanks
Old Mar 17, 2008 | 07:42 AM
earlybirds's Avatar
earlybirds
I recently had the same problem with my 1999 F250 5.4 V8. Through the excellent advice in this forum, I learned that it was likely that the IAC(Idle Air Control) was on its way out. Replacing the IAC fixed the problem. This is a fairly easy job. Search this forum for tips on replacing the IAC.
Old Mar 17, 2008 | 10:45 AM
i eat hybrids's Avatar
i eat hybrids
Yup your IAC is bad. Id either replace it or clean it. People down in the v-10 forum have cleaned theirs and it went back to normal.
Cost of a new IAC valve from dealership: $100 exactly
Cost of cleaning your IAC valve: IAC gasket from dealership (will need to be replaced): $6.00 Brake cleaner or CARB cleaner: $3-$6 give or take.
Total: $9.00 to $13.00.
Cleaning shouldnt take long or if u go with the route of replacin it, it shouldnt take long either.
If you go with the route of replacin it, here are the instructions. Its very simple:
https://www.ford-trucks.com/user_gal...&albumid=22274
Also, if you decide to go with the route of cleanin the valve and have a hard time finding where it is on the engine, those instructions should help u.
Hope this helps!
bbshriver
Sep 16, 2011 02:12 PM
86stepsideF150
Oct 7, 2009 02:55 PM
aleh61
Aerostar
Apr 8, 2009 04:26 PM
judmorrison
Sep 14, 2004 09:25 AM
TimLynch
Jan 15, 2004 03:32 PM
