Normal temperature for 400?
Old Feb 5, 2001 | 11:33 AM
bucket's Avatar
bucket
What is the normal operating temp for a 400? My gauge usually reads between the "M" and "A" in the "NORMAL". It does not overheat, even standing at idle for extended periods or in stop & go traffic. I'm thinking of installing a Perma-cool electric fan, the 14" or 16" in front of the radiator. I have the 3 row max cool Modine radiator, but I think Modine makes an even larger one. Hopefully the electric fan will cool it down enough. Thanks!
Old Feb 5, 2001 | 12:16 PM
Franklin2's Avatar
Franklin2
Are you sure your guage is right? The several ford cars and
trucks I've had seem to run around the "O". If you watch it
in the winter time the needle will swing up to the "O" and then
drop down. It will do this several times till it settles down
a little bit above the "O". From this I'm assuming the "O" is
the thermostat temperature which is around 190-195 degrees.
Old Feb 5, 2001 | 12:19 PM
martinb's Avatar
martinb
This is normal for a 195 degree thermostat. Extra fans won't help, but you can go to a 180 degree thermostat if it bothers you.
Old Feb 5, 2001 | 12:33 PM
Franklin2's Avatar
Franklin2
Between the "M" and the "A" is not normal unless it is very
warm outside and you are pulling a load. An aftermarket guage
might tell you more.
Old Feb 7, 2001 | 10:36 AM
DannyP's Avatar
DannyP
I would say the factory water temp gauge is no more accurate than the factory oil pressure gauge, which is little more than an idiot light. If you are concerned about your engine temp, I would first install a mechanical guage or an electric one with a sending unit to find out exactly what temp you are running.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Feb 7, 2001 | 12:48 PM
martinb's Avatar
martinb
When I changed to a 195 degree thermostat from a 180 the pointer now points between the m and a. If the temperature is not increasing during extended idle or in stop and go traffic the radiator is dissipating all the heat it needs to. Once the thermostat closes the temperture won't go down any more. Without commenting on the gage quality, if the pointer is in the normal range, by definition that temperature is normal.
Old Feb 7, 2001 | 03:40 PM
bubbaf250's Avatar
bubbaf250
Old Sep 6, 2004 | 10:36 AM
The Demon's Avatar
The Demon
Just when you think you are alone with your woes. . . I have this same issue with temperature. I have a 79 camper special with 400, C6 and usually the gauge reads at about O but if I stop for extended periods it can climb right to the edge of the NORMAL range. I contacted bubbaf250 and he stated that as long as the vehicle stays in the normal range then thevehicle is not overheating. I feel your pain because I had an 86 half ton, I always feel more manly driving a 3/4 ton for some reason, and all I changed was the thermostat and the temperature was rock solid from then on. I hate always watching my temperature gauge, fearful that the needle is going to cross the line. All these suggestions have been solid, now all I have to do is actually get off the couch and do something about it
Old Sep 6, 2004 | 11:25 AM
jopey's Avatar
jopey
so for the folks who do not have the stock normal guage. but have a guage which shows temp in degees F Whats good and bad?
Old Sep 6, 2004 | 11:41 AM
Torque1st's Avatar
Torque1st
Posting Legend
Drop a thermometer like the HVAC guys use into the radiator top tank. Figure it is ~10°F cooler there than in the engine. A good normal engine should run about 200-230°F If it is higher than that I would start to look for a cause. Your Instrument panel voltage regulator loosing it's ground connection can cause your dash gauges to read high.
Old Sep 6, 2004 | 10:20 PM
Matts72's Avatar
Matts72
I've installed a mechanical water temp gauge, and found it to give the same reading as the factory gauge.
I've also installed a 3 core Modine Super Cool aluminum radiator, and a 160 degree t-stat. Technically the engine runs in the safe range, but would be considered low for daily driving. This is my highway truck, and it runs right up to the R-M-A range on the gauge at highway speeds. I see nothing wrong with your settings, you will actually have a longer life out of your engine, because the hotter temperatures will eliminate carbon buildup in the combustion chambers, which will eliminate hot spots, and detonation / pre-ignition.
hope that helped...
NW 150
Nov 7, 2015 07:44 PM
Mikeman
Aerostar
Jan 2, 2013 11:09 AM
Marlinman10
Mar 16, 2012 07:44 PM
aerocolorado
Aerostar
19
Feb 1, 2008 04:35 PM
Superdave
Aerostar
28
Nov 11, 2002 06:09 AM
