Fuel Pump
Old Feb 7, 2001 | 07:45 PM
skud's Avatar
skud
Fuel Pump
I got a little question... What drives the fuel pump??? I have my 400 apart here. I put the cam in and I got a Comp Cams True Roller Timing set. I put top gear on the cam, and when I put the fuel pump on, the arm never comes into contact with anything?!?!?
Also, is the lower timing gear supposed to be a tight fit on the crankshaft, because I can put it on and remove it easily...
Thanks
Skud
Old Feb 7, 2001 | 07:53 PM
Bill_Beyer's Avatar
Bill_Beyer
Fuel Pump
> I got a little
>cam in and I got
>when I put the fuel
You forgot to put the "eccentric" or cam drive back on. It's a 1 or 2 piece unit that bolts on to the front of the cam gear and contacts the fuel pump arm. It's a very good idea to throw a little assembly lube on it so it has some lubrication at initial start up.
> Also, is the
>be a tight fit on
>it easily...
Sounds fine as long as you remembered to put the Woodruff key in before you installed it.
Old Feb 7, 2001 | 10:27 PM
skud's Avatar
skud
Fuel Pump
DOH!!!! Thanks... I totally forgot about that... I've been a little slow lately.
Thanks
Skud
Old Feb 7, 2001 | 10:40 PM
chevykiller's Avatar
chevykiller
Fuel Pump
skud
Apr 1, 2007 11:03 AM
skud
May 16, 2004 09:41 PM
skud
Dec 30, 2001 11:22 PM
skud
Aug 18, 2001 04:37 AM
skud
Jan 26, 2001 06:22 PM
