Mass Air conversion not working
Old Mar 16, 2008 | 09:33 PM
milbags's Avatar
milbags
Hey im new here and have a problem with a 89 f150.. i bought a used mass air conversion kit for my truck from ford racing and it seems that it will idle right but when you give it some gas i falls off the map and kinda studers and kinda smells rich and i was wondering do i have to change the firing order or is my computer gone bad or wiring somewhere.the kit came and i installed like i thought it should go with injectors 5678 starting from front to back on driverside and the 1234 starting from front to back on passenger side. and was told to cut off the map sensor vacuum tube .. someone please help
Old Mar 16, 2008 | 09:44 PM
EPNCSU2006's Avatar
EPNCSU2006
Did you disconnect the MAP sensor vacuum line?
Old Mar 16, 2008 | 10:05 PM
lmd91343's Avatar
lmd91343
Milbags,
Do you have an automatic or manual tranny? Is the kit for a manual or automatic? The part number on an A/T ends in "1". The M/T part number ends in "0". If you don't have the box, The part number is on the computer connector of the harness, by the pins.
The overlay harness has already been adjusted to convert to the truck 302 firing order.
What is the code on the computer box?
Are you sure that the intake hose from the MAF sensor to the throttle body is air tight?
The MAP vacuum line should be disconnected and PLUGGED. No need to cut anything. The MAP sensor should be exposed to the atmosphere.
I just went thru grief converting my '89 to MAF. It works perfect now. Hang in there!
Old Mar 17, 2008 | 08:42 PM
milbags's Avatar
milbags
Ya tried to play with it again to no luck. so i called ford racing and the guy wants me to time the truck to 8 degress and re gap the spark plugs to .30 and also set the idle on my bbk throttle bodie and check for codes on the computer and then we will see what the codes read and what not and see if it fixes it, what was your dalema when you installed yours
Old Mar 17, 2008 | 08:43 PM
milbags's Avatar
milbags
the computer is a a3m1 and the kit ends with 0 causes it's standard.. he said that it will work after this procedures .. it is running way to rich right now which i know it is
Old Mar 17, 2008 | 09:22 PM
lmd91343's Avatar
lmd91343
I had a couple of small problems: spark plug too hot; and fuel pressure too low.
Have you checked your fuel pressure? The diaphragm can rupture on the regulator drawing gas thru the vacuum line. Test it with the engine COLD!
Your computer is a early 90's M/T mustang computer which is right for the "0" kit.
How was the truck running before the conversion?
good luck,
Old Mar 17, 2008 | 10:48 PM
dhag911's Avatar
dhag911
HOw did you get a used kit?
Old Mar 18, 2008 | 05:09 AM
milbags's Avatar
milbags
im in the process or checkin fuel pressure right now and i bought the kit off a guy that hads sold his truck and no longer needed it anymore
nitebronc
1978 - 1996 Big Bronco
Apr 24, 2007 08:46 AM
jeep8589
Mar 19, 2003 07:29 AM
BobHaight
Sep 18, 2002 02:19 PM
Tdawg123
Jun 25, 2002 11:47 AM
