Iac valve question
Old Mar 16, 2008 | 06:26 PM
scrapyardking's Avatar
scrapyardking
Iac valve question
Well My IAC valve has been acting up latly the truck idles real high.
The auto parts store wants $80 for a new one, But I foung that if I unplug the wires runing to it the problem stops and the truck idles normal.
My question is if I keep it unpluged will it cause problems with anything else?
Old Mar 16, 2008 | 06:59 PM
Bobby82490's Avatar
Bobby82490
I left mine unplugged for a few days, and all i got was a check engine light(im actually thinking about unplugging it again).... i wonder if you could connect the wires going to the IAC to keep the check engine light off.....probably not though.
Old Mar 16, 2008 | 08:45 PM
fyre82's Avatar
fyre82
Clean it good and put it back. If it still acts up go find one at the wreckers.
Old Mar 17, 2008 | 03:24 AM
Pablo-UA's Avatar
Pablo-UA
First! Unplugged IAC may cause engine stall when cold.
If you cleaned IAC and porblem does not go away, check ECT and ECT wiring. May be ECU consider engine cold and increase idle speed.
Old Mar 17, 2008 | 07:41 AM
wtroger's Avatar
wtroger
If it idles fine unplugged then the IAC is either bad or you have a vaccum leak some where else it should idle very poor or not at all with the IAC unplugged.
Old Mar 17, 2008 | 07:46 AM
Pablo-UA's Avatar
Pablo-UA
Not sure. when my engine is hot I can unpug IAC and it is idling well, but CEL is on
Old Mar 17, 2008 | 08:26 AM
98Ranger2.5's Avatar
98Ranger2.5
I Pulled mine off and cleaned it with gumout carb cleaner spray then cleaned out the gummout cleaner with WD40 spray remounted it to the engine and everything was fine, and that was 2 years ago and still good.
Old Mar 17, 2008 | 09:29 AM
Bear River's Avatar
Bear River
Former ******
It seems to me you just need to replace it.
Old Mar 17, 2008 | 01:16 PM
PW01's Avatar
PW01
I tried cleaning mine, but ended up having to replace it.
Old Mar 17, 2008 | 01:33 PM
pawpaw's Avatar
pawpaw
I tried cleaning my IAC a couple of months ago with WD-40 & a foam swab, so far so good. (don't use a cotton swab, it's linty)
Mine was sticking where the plunger shaft goes through the shiney metal disc, into the electromagnet end. There were carbon deposits on the shaft, causing it to hang up.
Don't know long the cleaning will last, but I see one poster has had good luck for two years now, thats pretty danged good & certainly worth a cleaning try imo.
Old Mar 18, 2008 | 09:32 AM
rubydist's Avatar
rubydist
Unless you have a vacuum leak, it should not idle cold w/ the iac unplugged.
My experience w/ cleaning them is that they only last for a short time after that before they start to stick again, so once you clean it and confirm that was the problem, then I'd recommend replacing it.
Old Mar 18, 2008 | 11:30 AM
Bear River's Avatar
Bear River
Former ******
$80 for a new one seems very steep, I just replaced the one on my Mom's Aerostar, and it only cost $38. Try RockAuto.com, they probably have the best prices.
Old Mar 18, 2008 | 08:29 PM
98Ranger2.5
Rock auto has them starting at $21.79 for standard motor products brand or $53.99 for motorcraft brand
http://www.rockauto.com/catalog/rafr...&parttype=5028
f150forever
Sep 19, 2010 08:30 PM
hawgystyle
Jan 28, 2010 09:02 PM
Bobby82490
1997 - 2003 F150
Dec 4, 2009 02:15 PM
svdweb1
15
May 10, 2004 07:24 PM
dbuck50
Oct 25, 2003 10:19 AM
