Iac Question
Old Apr 28, 2004 | 07:42 PM
svdweb1's Avatar
svdweb1
Iac Question
Got another question. 1987 f-150 4.9. I get a real fast idle, almost up to 3000 rpm. I unplugged the IAC vavle and the idle dropped to 1000 to 1100 rpm when warm. When cold I have to keep on the gas for a minute or two. I believe I narrowed my problem to that part. I was wondering if there is a way to clean this valve to get it to work properly again. Trying to keep it as cheap as possible. The truck is a beater with other kinks to be worked out too, but I love it. Thanks for the help.
Old Apr 28, 2004 | 08:27 PM
Fordtech1's Avatar
Fordtech1
Yes, the IAC valve can be cleaned, as is the throttle body where the butterfly meets the bore, also, make sure the throttle body gasket is'nt sucked in.
Old May 3, 2004 | 08:57 PM
judge1971's Avatar
judge1971
Dont get mad at me for saying this but the best thing to clean these parts is only found at gm dealer it is called top engine cleaner in a blue spray can. I know I should not mention gm on a ford site but that stuff really works
Old May 4, 2004 | 12:02 AM
c96drumm's Avatar
c96drumm
Get a rope.
Old May 4, 2004 | 07:46 PM
judge1971's Avatar
judge1971
Talking
my wife would agree with the rope thing
Old May 4, 2004 | 08:00 PM
Egor's Avatar
Egor
I'm not positive, but I don't think your truck should idle at all with the IAC unplugged unless you are manually holding the throttle plates open. Sounds like a vacuum leak to me.
Old May 4, 2004 | 08:58 PM
c96drumm's Avatar
c96drumm
If the IAC is not closing all the way because it's sticking or something, it could cause that, but you're right, it could be a vacuum leak. TPS is another possibility.
Hey, svdweb1, how you doing with that?
Old May 4, 2004 | 09:12 PM
EPNCSU2006's Avatar
EPNCSU2006
The engine should run at the correct idle with the IAC unplugged.
Old May 4, 2004 | 09:33 PM
c96drumm's Avatar
c96drumm
First time I ever heard THAT.
Old May 5, 2004 | 08:26 AM
EPNCSU2006's Avatar
EPNCSU2006
You're supposed to be able to set the idle speed with the IAC unplugged, and all the accessories off. That's how the books I've read say to do it.
Old May 5, 2004 | 12:00 PM
c96drumm's Avatar
c96drumm
I guess I've read different books. My understanding is that you don't mess with the throttle stop screw and that the engine should either idle real low or die with the IAC unplugged. The idle speed is controlled by the computer with the IAC.
Old May 5, 2004 | 02:25 PM
EPNCSU2006's Avatar
EPNCSU2006
I've heard that too, mainly on this board. I've set it both ways, and both ways seem to work fine - as long as the idle tps voltage is at the correct value either way should be ok I guess. The way I understand it is that the IAC can bump the idle if needed (a/c, cold start, etc), but it shouldn't have to hold it up just to keep the truck running. Best I understand, the IAC should normally be closed at idle.
Old May 5, 2004 | 03:44 PM
c96drumm's Avatar
c96drumm
More than one way to skin a cat!
Old May 5, 2004 | 09:05 PM
Fordtech1's Avatar
Fordtech1
Here's an excerpt from the service manual:
"6 Shut engine off and install a specified feeler gauge between throttle return screw and throttle lever.
7 Disconnect the Idle Air Control (IAC) solenoid.
8 Start engine and run at 2500 rpm for 30 seconds.
9 Place automatic transmission in PARK, manual transmission in NEUTRAL.
10 Set idle rpm to the range using tachometer. "
Old May 6, 2004 | 12:15 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
With a fast idle, make real sure you don't have any vacuum leaks. Also take a close look at your TPS.
