95 info
Old Mar 16, 2008 | 04:34 PM
str8racing's Avatar
str8racing
95 info
installed new autolite copper core plugs, new wires, and cap and rotor now seems low on power. gapped plugs to .52 as per specs. on lable. what could i have done wrong? never had this problem before. Had trouble getting wires under intake on pass. side but can't find any broken wires.Also cap will wiggle by hand is this normal? Note this is on my wife's 95 f150 5.0 2wd.
Old Mar 16, 2008 | 04:46 PM
elmo8641's Avatar
elmo8641
are you sure you got the wires in the right spot. if you have 2 switch then you will be down on power. when you wiggle the cap is the whole distributor turning or just the cap. if the whole thing is turning then the timing is going to be off and that will make you lose power
Old Mar 16, 2008 | 05:27 PM
quicklook2's Avatar
quicklook2
cap does not sound like it is on right.
are you positive that you have all the wires on the right way?
triple check and make sure it is a diagram for your year engine.
Old Mar 16, 2008 | 06:18 PM
str8racing's Avatar
str8racing
the cap just seems to rock a little, will check wires again, but have never had a problem before.
mikerans
Jun 11, 2012 09:01 PM
deljac
Aug 25, 2011 12:20 PM
Broncobudy
1978 - 1996 Big Bronco
36
Sep 24, 2010 02:41 PM
95FordRangercjb
1983 - 2012 Ranger & B-Series
Dec 2, 2006 07:33 PM
#1bigmark
General Automotive Discussion
Nov 8, 2004 09:53 AM
