Tips on pumping fuel
Old Mar 14, 2008 | 02:47 PM
superduty4x4's Avatar
superduty4x4
Just got this in an email and thought I'd share.
> TIPS ON PUMPING GAS
> I don't know what you guys are paying for gasoline.... But here in
> California We are also paying higher, up to $3.50 per gallon. But my
> line of work is in petroleum for about 31 years now, so here are some
> tricks to get more of your money's worth for every gallon.
> Here at the Kinder Morgan Pipeline where I work in San Jose , CA we
> deliver about 4 million gallons in a 24-hour period thru the pipeline.
> One day is diesel the next day is jet fuel, and gasoline, regular and
> premium grades. We have 34-storage tanks here with a total capacity of
> 16,800,000 gallons.
> Only buy or fill up your car or truck in the early morning when the
> ground temperature is still cold. Remember that all service stations
> have their storage tanks buried below ground. The colder the ground the
> more dense the gasoline, when it gets warmer gasoline expands, so buying
> in the afternoon or in the evening....your gallon is not exactly a
> gallon. In the petroleum business, the specific gravity and the
> temperature of the gasoline, diesel and jet fuel, ethanol and other
> petroleum products plays an important role.
> A 1-degree rise in temperature is a big deal for this business. But the
> service stations do not have temperature compensation at the pumps.
> When you're filling up do not squeeze the trigger of the nozzle to a
> fast mode. If you look you will see that the trigger has three (3)
> stages: low, middle, and high. You should be pumping on low speed,
> thereby minimizing the vapors that are created while you are pumping.
> All hoses at the pump have a vapor return. If you are pumping on the
> fast rate, some other liquid that goes to your tank becomes vapor. Those
> vapors are being sucked up and back into the underground storage tank so
> you're getting less worth for your money.
> One of the most important tips is to fill up when your gas tank is HALF
> FULL or HALF EMPTY. The reason for this is, the more gas you have in
> your tank the less air occupying its empty space. Gasoline evaporates
> faster than you can imagine. Gasoline storage tanks have an internal
> floating roof. This roof serves as zero clearance between the gas and
> the atmosphere, so it minimizes the evaporation. Unlike service
> stations, here where I work, every truck that we load is temperature
> compensated so that every gallon is actually the exact amount.
> Another reminder, if there is a gasoline truck pumping into the storage
> tanks when you stop to buy gas, DO NOT fill up--most likely the gasoline
> is being stirred up as the gas is being delivered, and you might pick up
> some of the dirt that normally settles on the bottom. Hope this will
> help you get the most value for your money.
> DO SHARE THESE TIPS WITH OTHERS!
> WHERE TO BUY USA GAS, THIS IS VERY IMPORTANT TO KNOW. READ ON
> Gas rationing in the 80's worked even though we grumbled about it. It
> might even be good for us! The Saudis are boycotting American goods. We
> should return the favor.
> An interesting thought is to boycott their GAS.
> Every time you fill up the car, you can avoid putting more money into
> the coffers of Saudi Arabia . Just buy from gas companies that don't
> import their oil from the Saudis.
> Nothing is more frustrating than the feeling that every time I fill-up
> the tank, I am sending my money to people who are trying to kill me, my
> family, and my friends.
> I thought it might be interesting for you to know which oil companies
> are the best to buy gas from and which major companies import Middle
> Eastern oil.
> These companies import Middle Eastern oil:
> Shell.......................... 205,742,000 barrels
> Chevron/Texaco......... 144,332,000 barrels
> Exxon /Mobil............... 130,082,000 barrels
> Marathon/Speedway... 117,740,000 barrels
> Amoco...........................62,231,000 barrels
> Citgo gas is from South America, from a Dictator who hates Americans. If
> you do the math at $30/barrel, these imports amount to over $18 BILLION!
> (Oil is now $90 - $100 a barrel)
> Here are some large companies that do not import Middle Eastern oil:
> Sunoco..................0 barrels
> Conoco..................0 barrels
> Sinclair................0 barrels
> B P/Phillips............0 barrels
> Hess.......................0 barrels
> ARC0....................0 barrels
> If you go to Sunoco.com <http://sunoco.com/> <http://sunoco.com/> , you will
> get a list of
> the station locations near you.
> All of this information is available from the Department of Energy and
> each is required to state where they get their oil and how much they are
> importing.
> But to have an impact, we need to reach literally millions of gas
> Buyers. It's really simple to do.
> Now, don't wimp out at this point.... Keep reading and I'll explain how
> simple it is to reach millions of people!!
> I'm sending this note to about thirty people. If each of you send it to
> at least ten more (30 x 10 = 300)...and those 300 send it to at least
> ten more (300 x 10 = 3,000) .. and so on, by the time the message
> reaches the sixth generation of people, we will have reached over THREE
> MILLION consumers !!!!!!! If those three million get excited and pass
> this on to ten friends each, then 30 million people will have been
> contacted!
> If it goes one level further, you guessed it ..... THREE HUNDRED MILLION
> PEOPLE!!!
> Again, all you have to do is send this to 10 people. How long would all
> that take?
Old Mar 14, 2008 | 03:31 PM
quicklook2's Avatar
quicklook2
i just get it when i need it.
with little thought to all that.
Old Mar 16, 2008 | 04:01 PM
metmag52's Avatar
metmag52
I knew about the temp thing--but never thought about the dirt being churned up--
I ALWAYS buy Hess--it is always the cheapest around here, and they seem to have
stations everywhere...beside , I like their trucks at X-mas !!!
Gary
Old Mar 16, 2008 | 05:54 PM
Wild Karrde's Avatar
Wild Karrde
I've always heard the dirt thing, but heard from a friend of mine (who's got a PHD in chemistry, btw) that the temperature thing is actually a myth.
The tanks are buried far enough below the pavement that they stay at a fairly constant temperature all day/night. The only thing that might factor in on temperature in the tanks would be summer vs. winter, for the simple fact that EVERYTHING is colder in the winter and hotter in the summer. He said even then it's not a significant change.
Now he could be wrong, I can't say since I'm not a chemist nor do I have a degree in physics or thermodynamics... but the guy did seem to know what he was talking about, and I do know stuff below ground is a fairly constant temperature, from having lived near/around mines and miners most of my younger life.
Old Mar 16, 2008 | 06:31 PM
jroehl's Avatar
jroehl
I've seen that particular e-mail passed around before. The above poster's PhD friend was right about the temperature and buying gas--doesn't make a lick of difference. Modern vehicles reclaim the vapors from the gas tank, so that's a non-issue. And, the speed at which you pump is insignificant, too--pumping faster may create more vapors, but the difference is so incredibly small it's laughable to even consider pumping that slow. IMO, most pumps are too dang slow to begin with.
All these tips will result in one thing--spending more time at the gas station--time that you could be elsewhere doing something that earns far more money than you saved by standing on your ear while you pumped gas. I bet the Quik-E-Mart guys started this e-mail so that people who stay longer at the gas station and hopefully buy more $6 RedMonsters and $0.99 3-gallon cups of SugarFizz.
Jason
