Small Lift
Old Mar 16, 2008 | 01:58 AM
Redcoat's Avatar
Redcoat
Small Lift
Im looking to give my truck an inexpensive small lift. 1996 f-250 4x4. my springs seem a bit saggy all the way around, my truck sits close to level as it is. my first thought was to get some F-350 rear blocks to give the rear a boost. is this a good idea, or should i go with add a leafs? with blocks or add a leafs is my truck going to go out of whack at all? do i need drop brackets for the sway bar? If i get add a leafs for the front, is it going to mess up my front end, will it have to be adjusted at all? thanks
Old Mar 16, 2008 | 02:49 AM
ReAX's Avatar
ReAX
Any time you change the front end you should get an alignment. Add a leafs are going to be the cheapest and least flexible route. I say least flexible because blocks can add some extra torque to the leaf pack causing them bend in odd ways. Little blocks shouldn't cause a problem on the rear, but i'd stay away from 6"+ blocks. Just stay away from blocks on the front altogether.
Another option for you might be a body lift. They typically don't work with diesels, but a gasser should be fine. You can get 3" of lift for under $300.
Old Mar 16, 2008 | 02:52 AM
khadma's Avatar
khadma
Carpenter Local 745
Typical suspension system
http://www.roughcountry.com/ford_4wd_80-98_f250_4.html
CaptFX4
2004 - 2008 F150
Jan 18, 2013 05:57 PM
KG32A
May 20, 2011 01:18 AM
AntiHero55
Jul 22, 2010 09:50 PM
FX4 5.4
1997 - 2003 F150
26
Feb 12, 2007 11:26 AM
