Sponsored by: Real Truck
Speedometer correction?
Old Mar 15, 2008 | 03:44 PM
adamsre's Avatar
adamsre
Ok, I am having a lot of work done to my truck and I want it right the first time. I am adding a 7" Icon lift w/ 37" tires 4.30 gears and was planning to add the superlift tru-speed. I am being told by the shop that I do not need a truspeed since I am also about to order an X-cal 3 from one of the tuners (spartan, innovative etc). Do I need the tru-speed or not? I was under the impression that the SCT does not recalibrate the speedo. Thanks for your help, Ray
Old Mar 15, 2008 | 06:27 PM
ReAX's Avatar
ReAX
On an 05 you should be good to adjust the speedo with 37's. You will need to tell the tuner that you have that tire size and all other mods you have done. Where the tru-speed would be handy is if you change tire sizes (or you could just have tunes for the different tire sizes.)
Old Mar 16, 2008 | 03:12 AM
adamsre's Avatar
adamsre
ok, thanks. So the x-cal 3 will adjust for 37's?
Old Mar 16, 2008 | 03:18 AM
ReAX's Avatar
ReAX
My Sniper Special forces allows for up to 42" tires, I haven't used SCT but they should be similar. You'll have to contact a SCT dealer to confirm.
Old Mar 16, 2008 | 12:47 PM
jello's Avatar
jello
SCT will not adjust your speedo. You can change tire size in it for trans. control purposes. To correct the speedo you need a truespeed,speed wizard, or any other correction device.
Old Mar 16, 2008 | 02:32 PM
Green Ford's Avatar
Green Ford
I have the TruSpeed on mine because of tire and gear changes. It is perfect now.
Old Mar 24, 2008 | 09:09 AM
Mercury45's Avatar
Mercury45
FYI the gear ratio does not matter for speedometer changes on 1999- up superduty trucks... only tire size.
I have heard elsewhere the SCT does not correct for tire size.
I use a speed wizard on mine, 2 trouble free years and I have had (exact measurements : 36.5", 35.5" 31.7" tires (the last one is stock). Once setup my garmin GPS matches the speed quite well.
Kenny
Bowie
20
Aug 12, 2009 07:22 PM
DougD
Aug 1, 2004 09:02 PM
DoctorSmaX
Jan 17, 2003 01:37 PM
Tlattin
Computer Chips & Tuners
Oct 19, 2002 07:34 PM
Tlattin
Oct 16, 2002 04:53 AM
