AOD Year Diff
Old Mar 15, 2008 | 11:59 AM
Kraig84F150KingCab's Avatar
Kraig84F150KingCab
AOD Year Diff
Would an AOD from a early 90's truck fit in a 84?
Old Mar 15, 2008 | 01:36 PM
scottddove's Avatar
scottddove
anything is possible. Just look for all the right linkage and or electronics that goes along with the tranny. If is not a electronic model your biggest concern will be the tv cable that controls the shifting points of the tranny. Beware this cable is very sensative and only a slight bit out of adjustment will ruin your aod. If you dont know about adjusting it have someone who does help you or get educated on it before you take that first test drive. It literally will only take a mile or two to ruin a aod. hope this helps.
Old Mar 15, 2008 | 02:21 PM
ri_truck_guy's Avatar
ri_truck_guy
An early 90's AOD will work, but be careful about what you buy. In the late 80's Ford started using the AODE transmission, and phased out the AOD somewhere around 1992 or 1993. The AODE can be used with an older truck, but will require a the purchase of a seperate computer to control the transmission.
Old Mar 15, 2008 | 04:40 PM
Kraig84F150KingCab
I dont want to get into that, I just noticed on on Craig's list locally and though it would be good to have around. So setting up the linkage is a scarything from the sounds of it. Suppose this is true even when swapping out the car as well. Fun!
Old Mar 15, 2008 | 04:56 PM
Piffery1's Avatar
Piffery1
Link to AOD adjustments: http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Mar 15, 2008 | 06:54 PM
Kraig84F150KingCab
Thanks for the link Piffery! Doesn't sound that bad as long as you take your time and pay attention to the details.
Thank you!!
Old Mar 15, 2008 | 07:12 PM
scottddove's Avatar
scottddove
I tried using that guide that autozone has and it did not work for me. Like I said you better know what you are doing when you adjust this or you will ruin your tranny in a hurry. I had jasper engine put one in for me and they recomend using a pressure guage to adjust it poperly. How it is done I am not sure but I know found out the hard way it is a costly mistake. good luck
panman65
Nov 2, 2010 12:33 AM
Boss50
Jan 30, 2007 08:11 AM
krautwolf
Apr 3, 2005 08:37 PM
Katmandu
Aug 22, 2004 11:25 PM
Rick_Ford
Feb 8, 2004 12:29 PM
