need help. Shudder
Old Mar 15, 2008 | 08:59 AM
mswpj's Avatar
mswpj
need help. Shudder
Hello folks,
This is my first post. I have a shudder problem. When I accelerate moderately to heavily from a complete stop, there is a shudder and sort of a thud. I assumed it was the slip yoke, so I pulled the drive shaft and lubed the hell out of it. Same problems. I also recently changed the transfer case fluid. Does anyone have some sort of solution? Can the limited slip clutches cause this shudder in straight line acceleration? It is a 2004 FX4 supercrew. Thanks in advance! Matt
Old Mar 16, 2008 | 10:52 AM
mswpj's Avatar
mswpj
I forgot to add that the truck has 33800 miles on it. Thanks
Old Mar 16, 2008 | 10:55 AM
F0rdzTuff's Avatar
F0rdzTuff
Are you sure the shudder/thud is coming out of the rear, and not the XMSN?
Old Mar 16, 2008 | 02:51 PM
mswpj's Avatar
mswpj
I really hope it isn't the transmission. I just bought the truck.
Old Mar 16, 2008 | 05:54 PM
Twinsdad98's Avatar
Twinsdad98
The 04s did have some ls shudder due to clutch packs, but this would normally occur when turning and accelerating. If you lubed the slip yoke, I would look at the pinion angle. Search through the tsbs, I believe there is one for your issue.
Old Mar 16, 2008 | 06:11 PM
mswpj's Avatar
mswpj
Thanks. I noticed you also own a 2004. Did you have to use the wedges to change the pinion angle?
Old Mar 16, 2008 | 06:18 PM
wlgoble's Avatar
wlgoble
Shudder
I had a shudder while turning. And a shudder while straight line towing up a grade. Took it in for service and the Ford dealer said it was the clutch packs causing all my problems. They replaced the clutch packs, put in new oil, and modifier at a cost of $980.00. My extended warranty covered it. My truck now has just over 30,000 miles. I have not had a problem since they worked on it. They said it was a very common problem with the LS F150's.
Old Mar 16, 2008 | 07:06 PM
mswpj's Avatar
mswpj
I am going to try lubing the yoke some more. I used Amsoil synthetic grease, is there something else I should be using? I also may have not used enough. I also need to check the yoke for wear. I get that "bump" feeling when I accelerate. I also have that rear end whine at about 55-60mph. That fix calls for a new pinion and ring gear. Screw that. I don't know, there sure is a lot of troubleshooting ahead. Thanks again for the input. Forums are the best place for info. Matt
Old Mar 17, 2008 | 12:51 AM
redrush40's Avatar
redrush40
Hello,
I have the same shutter sometimes in my 05 FX4.
It basically is present, when I go from about 20-35MPH... or from 1st to 2nd gear in the Auto trans.
What the heck? I also recieved a letter in the mail from Ford stating that these trucks have some fuel injector problems...
It only happens once in a while, but it is annoying as heck!
TONY Z.
#40
Old Mar 17, 2008 | 09:04 AM
WilZol's Avatar
WilZol
My wife's CV does that about every 40K miles or so. I have the fluid changed in the tranny and it goes away.
Old Mar 17, 2008 | 09:25 AM
jmizell49's Avatar
jmizell49
Ford replaced the clutch packs in my 2004 screw and the problem went away.
Old Mar 18, 2008 | 08:04 AM
mswpj's Avatar
mswpj
well, I removed the driveshaft, and greased the heck out of it again, and it seemed to keep the thud, and or bump/shudder at bay. We'll see. I must not of used enough grease the first time. I read the TSB on pinion angle, and I was wondering how you would change the angle? Do you put wedges between the springs and the axles? I know it calls for a 1 degree wedge.
Old Mar 18, 2008 | 02:32 PM
ranger88a's Avatar
ranger88a
Yes, it is a wedge that goes between the axle tube and springs. If I remember correctly, according to the tsb, you have to measure, try one wedge and if that doesn't fix it try another degree wedge.
56/78/92EFFIE
Nov 10, 2016 01:53 PM
becraftj1276
Jul 29, 2014 12:02 PM
mswpj
2004 - 2008 F150
13
Feb 17, 2009 06:16 AM
RA81222
1978 - 1996 Big Bronco
Jun 14, 2006 07:37 PM
mrshorty
Feb 5, 2002 12:24 PM
