Engine swap
Old Mar 14, 2008 | 09:18 PM
QH rancher's Avatar
QH rancher
Smile Engine swap
I have an 82 half ton 4x4 with a 302. I also have a wrecked 96 bronco with 351w EFI. We have intakes and oil pans and it will bolt up to the tranny. My question is will the EFI engine run with the carb intake. I think it will but would appreciate some info.
Old Mar 15, 2008 | 09:52 AM
Franklin2's Avatar
Franklin2
Yes it will. You will need an older type distributor for the 351w(the 302 dist won't work), and add a electric fuel pump to the truck or swap the 302 timing cover with it's two piece pump eccentric and fuel pump mount, onto the 351w. Be careful with the waterpumps and fans. If the 351w has a serpentine belt setup, then the waterpump and the fan turn backwards compared to the older v-belt setup.
Old Mar 15, 2008 | 09:57 AM
QH rancher's Avatar
QH rancher
Thanks for the info Franklin2.
EvinrudeDude300
23
Mar 3, 2025 12:28 AM
Bigblockexplorer
Feb 2, 2008 02:09 PM
mudadiction
Feb 28, 2006 12:37 PM
hot rod 4X4
1978 - 1996 Big Bronco
Jan 1, 2004 02:13 PM
Njbmx
Jul 23, 2003 12:24 AM
