Bolt pattern diff's on transmissions
Old Apr 23, 2001 | 06:28 PM
white bread's Avatar
white bread
I was helped with my 351 question, but I need to know the difference between a big block bolt patterns and small block on transmissions. I have a 4-speed manual trans if it helps with anyones answer.
77 Ford 3/4 ton
Old Apr 23, 2001 | 10:18 PM
Franklin2's Avatar
Franklin2
franklin2
Non-member
1. "RE: Help Me!"
23-Apr-01, 06:56 PM (EST)
I have never seen this myself but there is supposed to be a casting ledge behind the distributor on a 351m. The block is flat behind the distributor on a 351c. I reason this to be, because both engines use the same distributor, but the 351m has a taller deck (block) and a wider intake manifold. It stands to reason you would have to step the taller block down to use the same length distributor as the shorter block (351c).
Remove | Alert Edit | Reply | Reply With Quote| Top
I pasted this from your question I answered from the other forum. If you know where the motor in question came from originally, this would also help in determining what type engine you have.
Old May 12, 2001 | 09:31 AM
rwjr's Avatar
rwjr
yes, there is a difference....an easy way to check is to measure between the top 2 bolts for the bell housing....a sb is about 5 1/4", and a bb is about 7 1/2", and an FE is, of course, round
Old May 13, 2001 | 01:11 PM
Bill_Beyer's Avatar
Bill_Beyer
