V-8 Engines
Old Mar 15, 2008 | 04:07 PM
duste's Avatar
duste
The 428 you want is probablly one of ford most sought after big blocks. You could have a 460 plus trans for alot less then a none running 428, even the bare block gets good money. Your cheapest performance upgrade in the intake and carb swap on your 390, than you can spend all the time you want looking for that dream engine and still have a good runner.
Old Mar 15, 2008 | 04:13 PM
germanford390custom's Avatar
germanford390custom
That sounds good. If you were to quote a possible price of an Interceptor 428, what would your quote be? Should I move forward with a 4 Barrel Edelbrock Intake Manifold and Carb or stick with the 2 Barrel Holley I have now?
Old Mar 15, 2008 | 04:24 PM
duste's Avatar
duste
428 interceptor= BIG DOLLARS, prices could range from 1000 to 10000, all depends on what you want to do with it. As with all engines, horsepower costs money. Your best bet is the intake and 4 barrell for the 390, a good running 390 is a nice engine.
Old Mar 15, 2008 | 05:03 PM
germanford390custom
I agree! I love my 390! I just wish it would stop leaking oil! That's really the ONLY problem the engine it's self has, the rest is carb related.
Old Mar 15, 2008 | 06:24 PM
65f100_352's Avatar
65f100_352
I would stick with the 390. Is your PCV valve working? That can cause an oil leak. Also if you have a mechanical oil pressure gauge, the tubing could be leaking. Just throwing ideas out there. As far as the 428, If you have a good eye at the junkyard, you might be able to get one out of a mercury. If you measure the stroke, and it comes out to about 4", then that is either a 410, which is a 390 block with a 428 crank, or a 428. Also look for FE's with a counterbalanced dampener, because all 352/360/390 & 427's were internally balanced, and the 410 & 428 were externally balanced.
Personally Id throw in a Comp 268 High Energy cam, 4bbl, and exhaust and I think that you would be very satisfied with that setup. The 268 has a nice little lope, and still has plenty of low end torque for towing.
Just my 2¢
Captain Mel
16
Sep 24, 2013 11:09 AM
OKC54f100
May 19, 2013 03:37 PM
Raintree55
18
Aug 20, 2003 11:22 AM
althoffaaron
Dec 13, 2002 09:39 AM
mtcwby01
Mar 6, 2002 06:08 PM
