Tips on pumping fuel
Old Mar 14, 2008 | 02:46 PM
superduty4x4's Avatar
superduty4x4
Just got this in an email and thought I'd share.
> TIPS ON PUMPING GAS
> I don't know what you guys are paying for gasoline.... But here in
> California We are also paying higher, up to $3.50 per gallon. But my
> line of work is in petroleum for about 31 years now, so here are some
> tricks to get more of your money's worth for every gallon.
> Here at the Kinder Morgan Pipeline where I work in San Jose , CA we
> deliver about 4 million gallons in a 24-hour period thru the pipeline.
> One day is diesel the next day is jet fuel, and gasoline, regular and
> premium grades. We have 34-storage tanks here with a total capacity of
> 16,800,000 gallons.
> Only buy or fill up your car or truck in the early morning when the
> ground temperature is still cold. Remember that all service stations
> have their storage tanks buried below ground. The colder the ground the
> more dense the gasoline, when it gets warmer gasoline expands, so buying
> in the afternoon or in the evening....your gallon is not exactly a
> gallon. In the petroleum business, the specific gravity and the
> temperature of the gasoline, diesel and jet fuel, ethanol and other
> petroleum products plays an important role.
> A 1-degree rise in temperature is a big deal for this business. But the
> service stations do not have temperature compensation at the pumps.
> When you're filling up do not squeeze the trigger of the nozzle to a
> fast mode. If you look you will see that the trigger has three (3)
> stages: low, middle, and high. You should be pumping on low speed,
> thereby minimizing the vapors that are created while you are pumping.
> All hoses at the pump have a vapor return. If you are pumping on the
> fast rate, some other liquid that goes to your tank becomes vapor. Those
> vapors are being sucked up and back into the underground storage tank so
> you're getting less worth for your money.
> One of the most important tips is to fill up when your gas tank is HALF
> FULL or HALF EMPTY. The reason for this is, the more gas you have in
> your tank the less air occupying its empty space. Gasoline evaporates
> faster than you can imagine. Gasoline storage tanks have an internal
> floating roof. This roof serves as zero clearance between the gas and
> the atmosphere, so it minimizes the evaporation. Unlike service
> stations, here where I work, every truck that we load is temperature
> compensated so that every gallon is actually the exact amount.
> Another reminder, if there is a gasoline truck pumping into the storage
> tanks when you stop to buy gas, DO NOT fill up--most likely the gasoline
> is being stirred up as the gas is being delivered, and you might pick up
> some of the dirt that normally settles on the bottom. Hope this will
> help you get the most value for your money.
> DO SHARE THESE TIPS WITH OTHERS!
> WHERE TO BUY USA GAS, THIS IS VERY IMPORTANT TO KNOW. READ ON
> Gas rationing in the 80's worked even though we grumbled about it. It
> might even be good for us! The Saudis are boycotting American goods. We
> should return the favor.
> An interesting thought is to boycott their GAS.
> Every time you fill up the car, you can avoid putting more money into
> the coffers of Saudi Arabia . Just buy from gas companies that don't
> import their oil from the Saudis.
> Nothing is more frustrating than the feeling that every time I fill-up
> the tank, I am sending my money to people who are trying to kill me, my
> family, and my friends.
> I thought it might be interesting for you to know which oil companies
> are the best to buy gas from and which major companies import Middle
> Eastern oil.
> These companies import Middle Eastern oil:
> Shell.......................... 205,742,000 barrels
> Chevron/Texaco......... 144,332,000 barrels
> Exxon /Mobil............... 130,082,000 barrels
> Marathon/Speedway... 117,740,000 barrels
> Amoco...........................62,231,000 barrels
> Citgo gas is from South America, from a Dictator who hates Americans. If
> you do the math at $30/barrel, these imports amount to over $18 BILLION!
> (Oil is now $90 - $100 a barrel)
> Here are some large companies that do not import Middle Eastern oil:
> Sunoco..................0 barrels
> Conoco..................0 barrels
> Sinclair................0 barrels
> B P/Phillips............0 barrels
> Hess.......................0 barrels
> ARC0....................0 barrels
> If you go to Sunoco.com <http://sunoco.com/> <http://sunoco.com/> , you will
> get a list of
> the station locations near you.
> All of this information is available from the Department of Energy and
> each is required to state where they get their oil and how much they are
> importing.
> But to have an impact, we need to reach literally millions of gas
> Buyers. It's really simple to do.
> Now, don't wimp out at this point.... Keep reading and I'll explain how
> simple it is to reach millions of people!!
> I'm sending this note to about thirty people. If each of you send it to
> at least ten more (30 x 10 = 300)...and those 300 send it to at least
> ten more (300 x 10 = 3,000) .. and so on, by the time the message
> reaches the sixth generation of people, we will have reached over THREE
> MILLION consumers !!!!!!! If those three million get excited and pass
> this on to ten friends each, then 30 million people will have been
> contacted!
> If it goes one level further, you guessed it ..... THREE HUNDRED MILLION
> PEOPLE!!!
> Again, all you have to do is send this to 10 people. How long would all
> that take?
Old Mar 14, 2008 | 03:06 PM
IceboxFX's Avatar
IceboxFX
good deal, im gonna start filling up in the morning now... im glad i only buy hess and it dosent come from saudi arabia.
Old Mar 14, 2008 | 03:21 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i usually fill up at 5 am anyway, no time at night
Old Mar 14, 2008 | 03:43 PM
scatgo's Avatar
scatgo
If You Care
http://www.terrorfreeoil.org/
Old Mar 14, 2008 | 04:22 PM
Robbgt's Avatar
Robbgt
Last time I fill at Mobile... Thanks for sharing this!!!
-Robb
Old Mar 14, 2008 | 06:23 PM
884x4broncoII's Avatar
884x4broncoII
i wonder where tesoro gets there crude from, thats where our company purchases 80-90 percent of our fuel from, i personaly burned threw over $2000 in tesoro fuel last month
Old Mar 15, 2008 | 12:05 AM
superduty4x4
What was that, about 3 tanks or so?
Old Mar 15, 2008 | 12:57 AM
jimwilsonmasonry's Avatar
jimwilsonmasonry
yep last time i get my diesel at speedway -its 4.19 anyway
Old Mar 15, 2008 | 11:08 AM
Towmanjbo's Avatar
Towmanjbo
Intresting ideas here but gasoline is gasoline. A citgo tanker fills up right next to a sunoco tanker from the same tanks in the tank farm. The Only difference is the additive added to the gas at the loading rack, about 7 gal for 8800 gall tanker. I know I used to drive a gas tanker.
Old Mar 15, 2008 | 11:14 AM
Towmanjbo's Avatar
Towmanjbo
The big companys rent space in the tank farm based on fuel metered into the tankers.
So if say 100,000 gal is sold this month to citgo they are responsible for replenishing that fuel to the tank farm collective.
Old Mar 15, 2008 | 11:22 AM
Towmanjbo's Avatar
Towmanjbo
This is why most tank farms have less than 10-12 tanks. Two to three for regular, 1-2 for super, 1-2 diesel, 1-2 heating oil, kero, jet-A fuel. Not one for each brand they sell.
