Engine upgrades
I guess I have a couple of questions that some of you fine Ford folk may have knowledge of first-hand, since most of the engines I've rebuilt in the past were bowties...
First is, if I go with an Edelbrock aluminum intake, would I be better off (for a semi-daily driver application) with a Performer series, or a Performer RPM? The engine I built for my IROC-Z Camaro had an RPM on it, and I loved it... The '63 Chevy truck I had used just the Performer series, and it seemed to be a touch lacking for my taste (engine internals and carb were very similar between the two).
Second is, I'm considering a cam upgrade. I would like to try and get a performance upgrade, but don't want to sacrifice fuel mileage to get it. Should I leave my stock cam in there or go with a new aftermarket? If I replace it, I'm not quite sure what I'd go with in terms of lift/duration... It's been a great many years since I did cam work on an engine, and I don't remember much about it. The two I'm looking at now are as follows...
1000-4000 RPM 197/209 dur .448/.472 lift 114 lobe center
1500-4000 RPM 204/214 dur .448/.472 lift 112 lobe center
Would either of these cams be a good choice for a truck I plan on driving around a lot, or should I leave well enough alone and just go with my head gasket/intake replacement?
Oh, and before I forget... my current carburetor is a Holley replacement for the stock carb (somewhere in the 550cfm range, can't remember for sure)minus the emissions attachments. Would I be better off with a larger carb (or possibly re-jetting my current one) or would it be ok on there with the new intake and possible cam upgrade? Fuel-wise, it currently works just fine. Plenty of power, and fair fuel mileage. The only real troubles I'm having are the piece of junk stock intake and the head gasket leaking coolant into the cylinders.
Any advice would be appreciated.
Another note I should probably mention is, the engine that was in the Camaro wound up in a K/5 Blazer for a while too. It had a touch too much torque for the IROC, and wound up cracking it's frame (a sad day in my book, but that's another story). Seems that the setup in that engine was pretty much perfect for that K/5, though... All torque was great for my off-roader.
The way I'd like to get my F-150 is pretty much for an in-town driver. The lack of overdrive hurts my highway mileage, but I rarely take it over 55mph anyway. More torque I figure would actually *help* in town, since it's mostly stop-and-go driving. I may be wrong on this, though... That's why I ask for other's advice before I commit to anything.
Your question about manifolds is fundamentally, one only you can answer. will you want the higher rpm power band of the (rpm) v the reg. performer? If so get headers and all that is needed to support it.
Sounds like the carb is cool. With all the work your talking about it sound as if your pretty mech inclined so buy a rebuild kit, clean it up good and try it out before you go any bigger.. carbs have sweet spot they perform best at ( power band-rpm-cfm) you may find you've created the one for carb and your self. Best wishes.
I'm going to be more inclined to the milder cam and the Performer intake, as I think I'll have better low-end with that combo. Since most of my driving is in-town, which means stop and go driving, low end torque is what I'll really need. The RPM intake and larger cam would be good if I felt like wrapping up the revs in the engine, but I don't really plan on doing that a whole lot. That Camaro of mine did a lot of street-style racing, and was wound up tight quite a bit, so I can see how the RPM intake was better in that application. Sticking with low-end power is the way to go for what I need, I believe.
My exhaust will eventually get an upgrade, but I doubt I'll bother with headers any time soon. Fitting them around the front axle on a 4x4 is a PITA from what I hear. Intake/cam upgrade + removing one of the cats and installing a higher flow muffler seems to be my best option for now (both labor-intensive and budget-wise). Later on I may work in a set of longtubes, but 'till then I'll just worry about getting it running well and looking good.
I was considering trading this truck off for a fuel-efficient car, but got to thinking... I'll be hard-pressed to find a fairly rust-free 74k original miles 80-86 bodystyle Ford 4x4 truck around here for the price I paid + the money I'd put into fixing her up. $900 for the truck and a few hundred more for the engine upgrades... Seems like a good deal to me. Most of the trucks of that era around here are so rusted out or wrecked they're basically rolling parts vehicles.
