Transmission Help
Old Mar 13, 2008 | 07:53 PM
Mike63's Avatar
Mike63
Transmission Help
I have just switched out the Automatic transmission on my 96 Eddie Bauer (4.0). During the test drive I noticed it was not going to second gear. What did I do WRONG? It has 238,000 miles on it.
Old Mar 14, 2008 | 04:23 PM
aquanaut20's Avatar
aquanaut20
Did you put a rebuid in or someone else problem?
Old Mar 14, 2008 | 05:11 PM
Mike63's Avatar
Mike63
I got the Transmission from a Used Auto Parts Yard. I Preparing to replace the Throttle position Sensor, that may be the problem.
Old Mar 14, 2008 | 07:12 PM
aquanaut20's Avatar
aquanaut20
So you might have someone elses problem, used A4LD and 4r44e are a losing bet.
Since you dont know the transmission, U may need professional diagnosis, be prepared to change it out.
Old Mar 16, 2008 | 10:05 AM
Bear River's Avatar
Bear River
Former ******
The 1st to 2nd shift is controlled internally by the transmission, with input from the vacuum modulator and kickdown cable. If it doesn't make the shift, the transmission is leaking internally and cannot build up the required pressure to make the shift. My guess is your old tranny was probably in better condition, rebuild it and put it back in, use the new one as a spare and rebuild it too.
mustangmatt
Feb 17, 2012 08:13 PM
twp
1997 - 2003 F150
Feb 15, 2010 06:49 PM
Alpine6
May 11, 2007 03:53 PM
Col Flashman
Dec 30, 2005 11:46 PM
gehrig
13
Aug 1, 2005 08:28 PM
