distributor advance
Old Jun 20, 2001 | 02:15 AM
Ben_E's Avatar
Ben_E
distributor advance
How much does the vacuum and mechanical advance in a stock late 70's 351m/400 distributor actually advance the timing when they are both maxed out? Reason I'm asking is because I have a new cam in my 351 and I want to set the timing as close as I can before I drive it anywhere. I would find out for myself but I think my neighbors might get mad. They did not seem too impressed when I broke in my cam with the new headers so I don't want to push my luck. Thanks!!!!!
Old Jun 20, 2001 | 11:33 AM
Franklin2's Avatar
Franklin2
distributor advance
They only thing you can do is set the initial timing with a light. The rest varies from dist to dist and requires lots of tuning and road testing. The fun is just begining.
Old Jun 21, 2001 | 01:33 PM
beartracks's Avatar
beartracks
distributor advance
My experience with the 351M/400 with a few mods indicates a craving for initial advance. I run 18 degrees initial plus about 20 mechanical for 38 total plus about 6 in the vacuum canister. I found that to get enough initial you tend to wind up with way too much total. You need a distributor with adjustments for vacuum and mechanical in order to do it right.
1977 Ford F-100
400m/c6
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Jun 24, 2001 | 02:15 AM
Ben_E's Avatar
Ben_E
distributor advance
I did a little homework, and I want to try and re-curve my stock distributor before I buy a new one. Has anybody tried those re-curve kits from Crane Cams?
Old Jun 26, 2001 | 12:58 PM
beartracks's Avatar
beartracks
distributor advance
I should note that I'm in ABQ,NM and am 1 mile avove sea level. When I go to PHX I have to retard the timing about 4 degrees or it pulls me throught the stop lights.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Old Jun 27, 2001 | 02:00 PM
butaford's Avatar
butaford
distributor advance
jbehuniak
Oct 27, 2016 10:25 PM
Crop Duster
Oct 10, 2016 04:51 AM
craigibc
Aug 15, 2010 10:14 PM
lewislynn
Mar 31, 2007 03:38 PM
2speed
Feb 17, 2003 05:00 PM
