Timing set installation
Old Jul 3, 2001 | 12:47 PM
4wdf150's Avatar
4wdf150
I have a 351m w/ 39,000 original miles on it from a 78 t bird. I am putting it in my 79 4wd f150, c6, 205 t case, 4.11 gears, dana 60 rear. I am putting in melling hi vol. oil pump, summit double roller timing set, and headers. The rest of the engine is stock w/ new gaskets and carb kit and all smog removed. The cam gear can be set at 0 deg. or 4 deg. advanced. What will be the best setting for this engine for gas mileage and low end power.
Old Jul 7, 2001 | 02:31 AM
Superdave's Avatar
Superdave
From what I've been reading on here, it would be 0. Or also known as straight up.
Superdave
94 Ford Aerostar XL 3.0L
82 Ford F250 4x4 XLT,400 CID,C-6 A/T,8700lb GVWR. Black & Silver
Old Jul 9, 2001 | 07:49 AM
4wdf150's Avatar
4wdf150
Thanks, I am going to try it on 0 and will let you know how it runs.
Old Jul 9, 2001 | 12:37 PM
1ole4d's Avatar
1ole4d
ThatFordGuy
May 16, 2011 11:25 PM
zaaac
22
Feb 7, 2010 12:41 AM
dtford
Mar 18, 2008 10:13 AM
dt466s
Feb 16, 2003 01:35 PM
bondo man
May 7, 2002 12:27 PM
