Transmission Question
Old Mar 14, 2008 | 12:53 PM
aklim's Avatar
aklim
Originally Posted by BanksPSD
Sounds good, I like the layman terms... I have been thinking about changing the TC anyway so i'll add the Valve body to my list.
How difficult is it to change the valve body? I'm semi mechnically inclined could i do it?
Call 1-870-422-3673 for the BTS VB
http://guzzle.rbmicro.com/bts.html will tell you how to install one
Old Mar 14, 2008 | 01:07 PM
BanksPSD's Avatar
BanksPSD
Well I just bought the "Banks Power Billet Torque Converter" and BD's Valve Body kit. I'll let you know how it works thanks again for all y'alls help!
Old Mar 14, 2008 | 02:07 PM
ggirten's Avatar
ggirten
Originally Posted by eldwood73
i want you to get a transmission cooler from a 6.o
I have the 6.0 Intercooler it came stock with my truck... I will look into the valve body and the TC. thanks a lot!
I believe Elwood was referring to a tranny cooler. The stock one is not heavy enough. Just had my tranny replaced because of heat. I ordered a new HD cooler to go with my radiator and found that mine didn't run through the radiator, so I ordered another on from a V10. Much bigger than stock. I have them both running in series. Don't want to rebuild again.
Old Mar 14, 2008 | 07:06 PM
BanksPSD's Avatar
BanksPSD
I just bought a Banks TC and a BD Valve body, so that will be on my to do list. Thanks for all of y'alls help, i'll let you know how it goes.
Old Mar 30, 2008 | 09:29 PM
BanksPSD's Avatar
BanksPSD
Ended up getting the Stallion TC... I also installed a new Throttle position sensor, Bryan at BTS said that might be the problem. Once i did all this problem went a way so I'm not sure what the actual problem was.
I think it was the Throttle position sensor throwing a bad signal to the computer...
GoodwinFord
2004 - 2008 F150
Nov 17, 2012 09:26 PM
mudracin74
Apr 23, 2010 06:59 PM
cleatus12r
15
Feb 20, 2009 07:02 PM
FTE Jason
Georgia Chapter
Jul 28, 2006 08:01 AM
sniper466
Jul 2, 2001 12:14 AM
