Sponsored by: Auxito
Window Regulator??
Old Mar 12, 2008 | 07:29 PM
boatnfish's Avatar
boatnfish
Window Regulator??
The truck is a 2001 Lariat supercab.
Issue is my drivers side window hits slow (sometimes dead) spots when going up and down. I have sprayed silicon on the tracks, but that doesn't seem to help much. I have noticed that in real rainy weather it works better.
I have also noticed that the window will **** (front drops) roughly 0.25 inch when you change directions (down to up), and may stall at that point. If I pull the window back (towards rear of truck) it starts to go fine.
So, my question is, does this sound like the regulator? If so, how much of a job is it to replace? Any unique things to know ahead of time?
Thanks in advance.
Old Mar 13, 2008 | 10:13 AM
k460's Avatar
k460
Bump, my 00 has the same issue
Old Mar 13, 2008 | 03:17 PM
Bobby82490's Avatar
Bobby82490
Try oiling where the window rides in. Just put the window down and spray a lubricant into where the window rides up and down at. I have done this and it works pretty good, just becareful about how you spray it, you dont want to cover the window in oil.
Old Mar 13, 2008 | 09:44 PM
mjunk1's Avatar
mjunk1
I'm not sure how the Ford's work, but I have multiple issues in other vehicles and they seem to be roughly the same. In the other cases, something had come un-done in the regulator and bent the scissor frame the window rides in. It took a good bit of effort to re-shape them and make them work, but in both cases I managed it. You might look inside there to make sure all the pieces are still bolted together right. If something is loose you would save a lot of time catching it early.
Old Mar 14, 2008 | 07:06 PM
boatnfish's Avatar
boatnfish
Thanks. I would say something is loose somewhere as the window will **** when going up. I think I will end up digging into it (when the weather gets warmer), but may just replace the regulator instead of trying to straighten it out. Of course that is provided it is bent.
Old Mar 28, 2008 | 08:07 PM
chapinjohn's Avatar
chapinjohn
I have a similar problem with a 2000 F-150 on both
front door windows. I think I will try to replace
one regulator as opposed to a motor. Can anyone
recommend the best place to purchase regulators.
Old Mar 29, 2008 | 09:16 AM
cleatus2015's Avatar
cleatus2015
I've been dealing with a similar issue. I rolled the passenger window down on my '99 F150, and it wouldn't roll back up. It had been working fine. I thought it was the motor; Actually, a fairly simple process. Basically, you take out 2 screws and lift the door panel UP and it comes off. Gently peel off the rubberized inner lining, and remove the speaker to get the lining off completly. Also, remove the inner portion of the window rubber on the top of the window sill so you can see down inside.
Removing the regulator would be extremely difficult, as far as I could tell; it's rivited in there with steel rivets. However, by removing the panel and liner, you should be able to easily apply silicone to the entire window track with the window up, and you might see if that works.
You can get the regulator at Autozone; will set you back about $60.
Old Mar 29, 2008 | 10:18 AM
dantsg's Avatar
dantsg
I have used silicon and it worked well. The left window on my 98 F150 is aleays faster.
66f100project
Sep 21, 2014 11:18 PM
DGMFORD
Dec 9, 2013 10:36 PM
Fuha
Feb 11, 2012 10:52 PM
ty20404
Jun 24, 2008 05:26 AM
