Electric Choke
Old Mar 12, 2008 | 06:28 PM
78'Ranger's Avatar
78'Ranger
Angry Electric Choke
My truck's choke seems to stay closed unless i open it by hand... I got up to drive my truck and the butterfly on the carb stayed closed so when i got home I opened the butterfly by hand and then was able to drive my truck around the block with no problem. Is there some sort of spring or linkage that might have disconnected from the butterfly to the electric choke? Thanks for your answers guys and gals!
Old Mar 12, 2008 | 06:34 PM
Mil1ion's Avatar
Mil1ion
There is a bi-metal spring inside the choke housing that heats and expands causing it to pull on a rod and opening the butterfly (Non-choke position)
When it is cold it causes the rod to activate the butterfly to close.
Electric chokes eventually burn up
It is a must they be connected to the stator terminal of the alt to increase the life of them.
Check the indexing of the choke housing.
yours should be set at the INDEX mark.
choke adjustment
21: Autolite 2150 choke plate pulldown adjustment
1. Set throttle on fast idle cam top step.
2. Note index position of choke bimetallic cap. Loosen retaining screws and rotate cap 90 degrees in the rich (closing) direction.
3.Activate pulldown motor by manually forcing pulldown control diaphragm link in the direction of applied vacuum or by applying vacuum to external vacuum tube.
4.Measure vertical hard gauge clearance between choke plate and center of carburetor air horn wall nearest fuel bowl.
Pulldown setting should be within specifications for minimum choke plate opening.
If choke plate pulldown is found to be out of specification, reset by adjusting diaphragm stop on end of choke pulldown diaphragm.
If pulldown is reset, cam clearance should be checked and reset if required.
After pulldown check is completed, reset choke bimetallic cap to recommend index position as specified in the Carburetor Specifications Chart. Check and reset fast idle speed to specifications if necessary.
Old Mar 12, 2008 | 10:12 PM
IZZYAZ's Avatar
IZZYAZ
My electric choke went bad a couple weeks ago. Took me a couple days to figure out why I couldn't go over 25 mph. Any who, I installed a manual choke in it, and thru out the electric choke. NAPA didn't have the electric choke on hand I needed, but they had the manual conversion kit. I think it was $15 or so. I installed the 'pull' just under the key, so when it's cold out (below 20 degs) I just give it a pull hit the key and off I go.
Old Mar 13, 2008 | 10:57 AM
n9lhm's Avatar
n9lhm
Is it strictly electric, or is there heat on it from the exhaust manifold too?
Many of the heat stove pipes rust off from the heat, and then the choke doesn't open. There should be a complete path from the top of the air horn on the carburetor, through the choke stove, back up to the choke housing. If all the pipes/hoses are intact, take the line loose at the choke housing and see if you can blow back through it to see if it's obstructed.
Old Mar 13, 2008 | 11:25 AM
OldMetal's Avatar
OldMetal
And if it's electric make sure there is voltage to it.
Old Mar 13, 2008 | 11:35 AM
Mil1ion's Avatar
Mil1ion
If hooked up to the stator.. the engine has to be running for power to be there
Old Mar 13, 2008 | 11:46 AM
fmc400's Avatar
fmc400
MSEE
That's correct. It's a 12V three-phase sine wave. If you hook your DC meter to it, it will read around 6-7V RMS, so don't be alarmed if you measurement looks "low." It's because of the shape of the signal and the calculation the meter does.
Old May 16, 2008 | 04:24 PM
1974Perry's Avatar
1974Perry
Old May 16, 2008 | 04:26 PM
1974Perry's Avatar
1974Perry
curious
just wondering if there's anyone around austin or taylor that could peak at my 1974 F100...it's got a 360.
Old May 16, 2008 | 05:50 PM
montana_highboy's Avatar
montana_highboy
Save your self the headache and just install a manual choke, 10 bucks and 30 minutes later you'll be much happier.
Old May 16, 2008 | 10:57 PM
4x4 Bart's Avatar
4x4 Bart
In my experience you can use a manual choke to save on fuel consumption. You just use it when you need it and once rolling you can taper it off much quicker than an electric.
Old May 17, 2008 | 07:13 PM
78Ranger_GARedNeck's Avatar
78Ranger_GARedNeck
well make sure you got power to the choke..mine keeps blowin the fuse..reckon ima change the wires tomorrow so it feeds from the back of the alt.
boboh1
Apr 21, 2013 08:45 PM
kdbenton
Jan 22, 2013 03:22 PM
kpc3my
Dec 7, 2011 09:31 PM
pit_of_pity
Oct 2, 2009 10:29 PM
toms86ford
Apr 17, 2007 05:13 PM
