butterfly jams
if I tap on it for a little bit and keep working at it, it will suddenly move freely and the truck runs fine.
I am suspecting the electric choke, but I thought I would consult the powers of the forum for help on this one.
I resurrected this truck from death and drive it occasionally to work, so its a work in progress....
any help would be appreciated.
Welcome to the forum!
As was said by 1986F150six, check to see if the choke is coming on.
The factory choke is both electric assist and Thermostatic contolled. Does the choke still have an hot air tube hooked up from the choke stove in the exaust manifold? Does the tube have any holes to alow cold air into the choke housing? Is the tube missing etc...
These problems would close the choke and cause the fast idle cam to engage the throttle, keeping the butterfly open at fast idle.
This will not cause the butterfly to jam in both directions though, unless there is a defective part or bent linkage somewhere.
the piston piece inside the choke looks like it was broken off from the shaft the butterfly sits on.
This piece must be getting pushed up by the hot air from the manifold and sometimes jamming the rod so the butterfly can't move.
Looks like the only way to fix this "well" is to replace the carb.
See if any of these people will pull it off and ship it to you.
1982
Carburetor
Ford Truck F100 VERIFY #S,STOCK NO. #76445 A #76445 $269 Ronnies Late Model USA-AR(North-Little Rock) E-mail 1-888-945-8881
1982
Carburetor
Ford Bronco Full Size (4.9L), FED, w/o AC A 4N0322 $150 Pick A Part, Eugene USA-OR(N.-Eugene) Request_Quote 1-800-439-3061 Request_Insurance_Quote
1982
Carburetor
Ford Truck F100 STOCK NO. #320 #320 $100 ARichner Auto Parts USA-PA(Milesburg) Request_Quote 1-814-355-3851/ 1-888-572-3428 Request_Insurance_Quote
1982
Carburetor
Ford Truck F150 ID #E2TE-BVB- 67956 A C3160 $75 2060 Auto Parts Inc. USA-NY(Buffalo) Request_Quote 1-800-955-7445 Request_Insurance_Quote
1982
Carburetor
Ford Truck F150 SINGLE BARRELL 071808 75
--Can--
$75.00 A-1 Auto Recyclers Can-ON(Brantford) Request_Quote 519-756-0410 Request_Insurance_Quote
1982
Carburetor
Ford Truck F150 one barrel nice,STOCK NO. #73593 #73593 $65 Auto Planet Automotive II USA-MI(Detroit) Request_Quote 1-313-931-0100 Request_Insurance_Quote
1982
Carburetor
Ford Bronco 7652 S (R) A 124-C $50 Select Parts, Inc. USA-DE(Claymont) E-mail 1-866-570-6522 / 1-215-423-6522
1982
Carburetor
Ford Truck F100 A 00002980 $50 Haynes Auto Parts USA-GA(Commerce) Request_Quote 706-335-5166 / 404-524-4038 Request_Insurance_Quote
1982
Carburetor
Ford Bronco 4.9 W/AC REBUILDABLE K20470 $45 Litchfield Recycling and Auto Salvage, Inc. USA-MN(Litchfield) E-mail 877-393-2293 / 320-693-2546
1982
Carburetor
Ford Truck F150 300-6 SE4216 $40 Brown Brothers Auto Recyclers USA-ID(Burley) Request_Quote 208-678-7580 / 800-257-0869 Request_Insurance_Quote
1982
Carburetor
Ford Truck 150 4.9L A 5049 $35 Rubin Auto Parts, Inc. USA-NY(Pine-City) E-mail 1-800-247-8246
1982
Carburetor
Ford Truck F150 302 GOOD MOTOR,STOCK NO. 073344042 073344042 $Call ARichner Auto Parts USA-PA(Milesburg) Request_Quote 1-814-355-3851/ 1-888-572-3428 Request_Insurance_Quote
1982
Carburetor
Ford Truck 100 YEAR NUMBERS WRONG $Call Swamp's Used Auto Parts USA-PA(Upper-Black Eddy) Request_Quote 1-610-294-2941 Request_Insurance_Quote
1982
Carburetor
Ford Truck F150 1-82,2BC,5.0 981080 $Call Salvage One Used Parts USA-VA(Coeburn) Request_Quote 1-276-467-1070 Request_Insurance_Quote
1982
Carburetor
Ford Bronco VERIFY ID 052405 $Call LeBarron's Auto Salvage, Inc. USA-PA(Dover) Request_Quote 1-717-292-3159 Request_Insurance_Quote
1982
Carburetor
Ford Truck 150 4.9L,1BL A4103 $Call AMT Parts Recyclers USA-ID(Meridian) E-mail 800-887-1978 / 208-888-1978
Year
Part
Model Description Part
Grade Stock# US
Price Dealer Info
OR
Request a Quote from hundreds of recyclers
Remanufactured carbs are not what they used to be...
