Concerned about oil pressure
Old Aug 14, 2001 | 10:01 PM
1ole4d's Avatar
1ole4d
Now that I have a manual gauge hooked up I can now tell what this hunk-a-junk is doing. What is the normal PSI the 351M is supposed to be at for the oil pressure? When mine idles at 500rpm it shows between 35-40psi. When I run it up to 1000rpm it jumps to 60psi. The oil pressure flucuates (however you spell it) with the engine speed. Is this normal? If not what could be causing it? I know she uses oil bad. Hell...I'm running 20W 50 right now. Any ideas?
Robert
1978 F-150 4x4 Stepside 351M
Please don't pull out in front of me! The last thing I want to do is play identify the pieces with you or your car.
Old Aug 14, 2001 | 10:38 PM
Franklin2's Avatar
Franklin2
Normal- and that is very good oil pressure.
Old Aug 14, 2001 | 10:42 PM
1ole4d's Avatar
1ole4d
[font size="1" color="#FF0000"]LAST EDITED ON 14-Aug-01 AT 11:48 PM (EST)[/font][p]So it is supposed to change with the rpm like that? If that is normal then, at what low and high psi should I get concered at?
Robert
Old Aug 14, 2001 | 11:57 PM
bsprowl's Avatar
bsprowl
Well it won't get so high that the pressure can hurt the bearings. That's almost a myth. Takes a high pressure pump and a very close tolerance rebuild.
When hot and idling: the pressure I want is at least 3 pounds and it should quickly rise with the engine speed. Minimum of 10 poounds at 1000 to 1200 RPM; 15 pounds at 2500 RPM; and 20 pounds at 4000 rpm.
The shop manuals may give some other values but I never notice them. When it falls below any of those numbers I start thinking rebuild.
Bob
'66 7 Litre, top loader, 3.25 Traction-lock, Sidewinder Intake, SCJ Exhaust
'88 F150 LWB 4x2, XLT Lariat, 302, 5 speed, 3.08
'99 Ranger, 4x2, 3.0, 5 speed, 3.73 posi
Old Aug 15, 2001 | 10:53 AM
bubbaf250's Avatar
bubbaf250
fordopie
Mar 29, 2012 09:08 AM
romeodz
1997 - 2003 F150
Nov 4, 2011 09:58 PM
Titus136
Apr 4, 2011 08:02 PM
RyAnIs1
13
May 23, 2009 07:13 AM
siphor84
1978 - 1996 Big Bronco
Sep 26, 2003 01:41 PM
