Oil pressure problems
I just bought the vehicle from an auction, it's in pretty bad condition, but it's almost back to a good running state (replaced several things from an ECT sensor to a cracked manifold). After those and some other repairs, the vehicle is running a lot better, but still not running all that great.
The following problems are most evident right now:
-It gets REALLY hot REALLY fast. After starting it, not even a mintue later the exhaust manifold is too hot to touch
-At idle (right now its idling at about 600 RPM when warmed up), the oil pressure gague (this is the dash gague, I haven't checked it with a shop gauge) goes to zero and the "Engine" light comes on, but then returns to normal presssure when RPM is over 2000 and the light goes off.
-Once the engine is hot, if you let it sit at idle for a few mintues it will start to smoke out the exhaust manifolds and buck like it has no oil (when it has a full oil level)
-It's running a little rough and failing emissions with high HC (possibly because it's so hot i'm getting a pre-ignition?)
...okay, so it obviously is having some kind of oil problem. It would be really nice if all I had to do was do a flush out the engine and then replace the oil pump and screen, etc... However, when I changed the oil it was blacker than night, and the filter felt like it had a brick in it. I'm afraid that the engine has been run in this condition for a long amount of time by the previous owner, and that an engine rebuild may be in order.
Any thoughts about this would help, specifically I'm looking to see how probable it is that the engine is seriously damanged and needing a rebuild, and any recommendations for getting the oil pressure back to normal.
Also, if someone knows how to check the pressure with a shop gauge that would be grealy appreciated.
Thanks,
Robert
...okay, so it obviously is having some kind of oil problem. It would be really nice if all I had to do was do a flush out the engine and then replace the oil pump and screen, etc... However, when I changed the oil it was blacker than night, and the filter felt like it had a brick in it. I'm afraid that the engine has been run in this condition for a long amount of time by the previous owner, and that an engine rebuild may be in order.[/B]
Robert
[/B]
Good luck Robert. I hope problem turns out to be less fatal than I think.
Best -
Joe Horn
'93 EB 302
You are right about the lifters, they do clatter when it's hot and at idle. The "bucking" i'm talking about it the engine acting like it's about to overheat and stall out.
Either this weekend or next I'm going to be pulling the oil pan to take a look at what's going on down there, so I'll let you know how that goes.
Thanks,
Robert
