Stiff Clutch
Old Mar 11, 2008 | 08:55 AM
387designs's Avatar
387designs
Stiff Clutch
I recently did the clutch on my 85 f150 and I did not have an alightment tool, I did make a great effort to make line it up and it went in fine. I did the clutch on my friends 99 f150 with an alighnment tool. The difference is his feels smooth and mine is very stiff. Mine has not been driven due to the lack of exhuast and a little wiring left to be done. Should I take it apart and use an alighnment tool?
Thanks,
Sean
Old Mar 11, 2008 | 11:57 AM
subs1000w's Avatar
subs1000w
ive installed many clutches without an alignment tool and as long as the trans went in ok leave it alone cause as soon as you start the engine is should auto align
the other thing it could be is if you have a hydro clutch you may need to bleed it somemore
or theres somthing wrong with your pressure plate
Old Mar 12, 2008 | 09:05 AM
387designs's Avatar
387designs
It is a hydro clutch but external slave fortunately. So I will wait till I can drive it before making the final verdict.
Old Mar 12, 2008 | 05:28 PM
andym's Avatar
andym
The alignment tool is just to make sure the tranny slides in through the splines in the clutch and then into the pilot bearing. If your truck is together, then you have no need for an alignment tool.
Old Mar 12, 2008 | 07:00 PM
85e150's Avatar
85e150
Check your clutch set up from the pad on the pedal to the fork in the bell.
Your vintage was subject to firewall (floors in vans) flex. In the van, it puts the rod to the master in a bind. Not sure this could happen in the F series. But, anything that bends can cause a bind somewhere.
E30tdf
Jul 22, 2025 10:58 AM
jakif23
Jul 1, 2022 08:44 AM
scktwrench
Feb 4, 2012 09:09 AM
killercarpenter
1997 - 2003 F150
May 24, 2010 08:30 PM
antunez13
Apr 7, 2008 11:14 PM
