4r100 problems
Old Mar 11, 2008 | 12:47 AM
Wht89gt's Avatar
Wht89gt
4r100 problems
I am having problems with my newly acqired 2000 4wd excursion. I pumped the tranny fluid out and flushed it with like 20 quarts doing the back cooler line and letting it empty out anyways i get code po705 trans range sensor??? But even more important it shifts 1-2 fine then nothing else doesnt go in 3or 4 the od light will not come on when i hit the button hit it several times while driving and nothing the fluid looks great fresh and reddish no bad burnt smell??? What and where is the trans range sensor? I cant seem to figure this out there is no metal on the drain plug please help!
Jonathan
Old Mar 12, 2008 | 11:44 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The transmission range sensor (TRS) is the sensor on the driver's side of the trans where the shifter cable attaches to the trans. It's the plastic part that is held on by two bolts, and has a wiring harness attached.
aclaybor
Apr 1, 2014 02:14 PM
neura
Escape & Escape Hybrid
Nov 16, 2012 03:31 PM
autotech2
25
Oct 16, 2011 12:37 PM
Fordsflylow
Modular V10 (6.8l)
Sep 20, 2008 06:11 AM
rogarl
Oct 31, 2005 08:48 AM
