92 351 for towing?
Old Mar 10, 2008 | 10:24 PM
92150351W's Avatar
92150351W
92 351 for towing?
hello all!
I ahve done alot of reading, but just get more confused. I have a 92 f150 with a 5.8 and an e4od. I tow an enclosed landscape trailer everyday and I am looking for more torque for pulling. The truck is stock at this point. I am looking for the simple upgrades as far as exhaust and intake and cams or what not. any suggestions as well as links would be great! thanks in advance
Old Mar 11, 2008 | 07:49 AM
Conanski's Avatar
Conanski
Drop the whole exhaust and install longtube headers and a custom 2.5" single.
Then add 1.7 roller rockers.
Old Mar 11, 2008 | 08:51 AM
92150351W's Avatar
92150351W
hey thanks for the reply. How hard are the rollers to install? i found a set for like 110 does that sound about right?
also, I see that you said to use a single exhaust is that to keep up the backpressure?
Old Mar 11, 2008 | 09:48 AM
Kemicalburns's Avatar
Kemicalburns
i would honestly do gears first. the gains will be far better then what motor upgrades you do at this stage. He exhaust is a must regardless though. if you are towing daily look into running 4.10's front/rear especially since you have an OD tranny.
Old Mar 11, 2008 | 09:53 AM
Conanski's Avatar
Conanski
Not sure on the price, just remember you get what you pay for in terms of quality. They are relatively easy to install, you have to remove the upper intake, valve covers, and then swap the rockers.
No that's a misconception, back pressure kills power so you don't want a restrictive system like the stock exhaust, but maintaining high air velocity builds more TQ. Best results will be with a high flow cat and muffler and mendrel bent pipe, this will flow lots more than the stock system overall and complement the longtube headers. People put way too much exhaust on these truck in general, and loose performance in the process.
Old Mar 12, 2008 | 08:30 PM
92150351W's Avatar
92150351W
thanks for the replies..
with the 1.7 rockers, should i look into a new cam?
Im running 4.10's now btw
have a e40d tranny, should i look into a shift kit for pullin about 4K lbs daily?
Old Mar 12, 2008 | 09:13 PM
Conanski's Avatar
Conanski
If you're up to it, sure. You pretty much have to strip the motor to change the cam, but it's the best bang for your buck on these motors, IMO, the 5.8 in particular can use all the cam it can get. You could use 1.7 rockers with the cam I have, but if you go much bigger you'll need valve springs as well. There's no point to going beyond 0.500" lift either as the heads don't flow beyond that, but get as much as you can below that.
Old Mar 12, 2008 | 10:01 PM
92150351W's Avatar
92150351W
thanks conanski, so your saying that the crane in your sig would work ok for my truck?
also what are your opinions on the shift kits?
Old Mar 13, 2008 | 08:43 AM
Conanski's Avatar
Conanski
for both those, hard to believe the difference these few mods make.
Old Mar 13, 2008 | 10:03 AM
Blurry94's Avatar
Blurry94
There are companies that make aftermarket valve bodies for E4OD's, and believe B&M make a shift kit for it as well. That and a Powerstroke trans cooler and deep aluminum trans pan and your transmission will remain cooler under heavy loads. One thing with a valve body or a shift kit is that they will shift hard all of the time; they do not regulate the TV pressure at lighter engine loads, that is done by programming.
I would suggest having a shim kit handy if you plan on doing a 1.7 RR swap.
Aviationinfo
Jun 1, 2016 06:35 PM
SideWinder4.9l
Dec 18, 2009 11:44 AM
Car Guy
Aerostar
15
Mar 8, 2009 09:31 PM
etherboy2000
Aug 21, 2003 05:32 PM
pr
Mar 21, 2001 04:42 PM
