Would it be worth it.
Old Mar 10, 2008 | 01:05 PM
CowboyFromHell's Avatar
CowboyFromHell
i found a 1978 F250 with a little rust above the rear wheel wells for 400 dollars. it has a big block 351 and a c6. the link is www.ksl.com/index.php?=218&ad=218878$cat=103&lpid=4. tell me if you think its worth it.
Old Mar 10, 2008 | 01:23 PM
BigGrizz76's Avatar
BigGrizz76
your link doesn't work...if it runs and drives, then yes buy it...
A 351C is NOT a bigblock. In reality, a bigblock is defined by the
bore spacing. A 351C shares the same bore spacing as a 351W, 302 and
289. 351C and 351W, 302, 289 heads can bolt to the others blocks.
Again, a 351C is NOT a bigblock. Put a 429 or 460 crank next to a 351C
crank with no labels. Tell me which is a bigblock. It will be obvious.
Put a 460 block next to a 351 block. It will be obvious.
Ford called the winsor block family the small blocks, the 351 C,M,& 400
are called medium blocks, and the FEs and 429-460 were the big block.
found the above online and I believe it is accurate
gnwalker's Avatar
gnwalker
When I went to the link it just brought up the KSL home page
Old Mar 10, 2008 | 01:31 PM
Mil1ion's Avatar
Mil1ion
Old Mar 10, 2008 | 04:45 PM
CowboyFromHell
srry grizz. my dad has a 400M in his 77 f150. it takes a big block intake manifold. the mounts are same and so are the bell housings. i could bolt his 400M into my 85 with a 460
Old Mar 10, 2008 | 05:25 PM
Mil1ion's Avatar
Mil1ion
Yes they share the 385 engine family bellhousing and the 400 engine mounts because the 351M/400 are the same except for pistons/rods/crankshaft
Actually only the 351M gets the M in it.
the engine family is the 335 series which include the 351C/351M/400
and they are all considered Small blocks.
This is the only 78 I see on that site
http://www.ksl.com/index.php?nid=218...49&cat=&lpid=1
Old Mar 10, 2008 | 06:14 PM
fdude64's Avatar
fdude64
if thats the truck it is awful clean for $650.00
Old Mar 10, 2008 | 07:07 PM
guitar_demon's Avatar
guitar_demon
if thats the only thing wrong with it, then get it for sure. if nothing else theyre fun to work on
by the way, your name 'cowboys from hell' is it safe to assume your a pantera fan?
Old Mar 10, 2008 | 07:08 PM
CowboyFromHell
No i'm not a pantera fan. I like country only
Old Mar 10, 2008 | 07:09 PM
bucks77ford's Avatar
bucks77ford
$400 is cheap.......Heck I just spent over $200 for new door panels
Old Mar 10, 2008 | 07:12 PM
CowboyFromHell
When you are on the ksl homepage there is a little thing above the vehicle search bar that says auto parts. click on that the truck is on page 7 or 8
Old Mar 10, 2008 | 07:39 PM
guitar_demon
hah gunrack and all, looks like its missing the grill shell?
does it not run? (listed under auto parts no running cars)
Old Mar 10, 2008 | 07:42 PM
CowboyFromHell
it runs they just listed it under there cause its cheap. and yea its missin the grille shell
