Boost gauge. Dumb Question.
Old Mar 9, 2008 | 08:16 PM
Brianut's Avatar
Brianut
So where exactly do I hook the other end of the tube up to?
Obviously one end goes to the gauge but where does the other end hook too?
I assume just somewhere on the possitive side of the turbo but are there any prefered places?
Thx
Old Mar 9, 2008 | 08:56 PM
nhill2090's Avatar
nhill2090
there are several options:
1)delete the air intake heater and put it in an AIH delte plug you can make or buy from one of the vendors here
2)tap the tube into the intake manifold
3)cut the map line and use the t-splice to mount the gauge
Old Mar 9, 2008 | 10:00 PM
Layson's Avatar
Layson
Just T into the map sensor line... all you need to do is just get a couple inches of hose and clamp it where it connects to the Y pipe then install the T then hook up the map sensor line... that way if you sell the truck you can just take out your boost gauge...
this can help visualize everything...
http://www.dieselmanor.com/diy/PSD3-...73gauge-p1.htm
Old Mar 10, 2008 | 09:56 AM
Brianut's Avatar
Brianut
Thx guys, it all makes sense now.
Old Mar 10, 2008 | 10:14 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Here's a pic of mine. It's the little clear plastic line going into the Y:
Old Mar 10, 2008 | 02:29 PM
Layson's Avatar
Layson
That is pre intercooler correct? Isn't the map line after the intercooler... Wouldn't that yield a little different numbers...
Old Mar 10, 2008 | 02:37 PM
sflem849's Avatar
sflem849
Word.
I and Pete F250_ are thinking on doing a pre and post IC. This will help you locate where your leak is. They have cheap Parker valves and then you can use one gauge and a valve and get pre and post IC readings.
The map line can BARELY be seen in the pic. Look where the red and yellow vacuum lines cross each other. That is the MAP line hiding in back inside a wiring loom cover.
The numbers will be a bit different, but a lot different if there are leaks in the IC/Cold Boots.
Old Mar 10, 2008 | 02:49 PM
Texas Outlaw
Not a liberal...
I dunno, never had any problems. I can make 25#s pretty easy when I want to. I do check my boots often and tighten as needed so maybe that's part of it.
Old Mar 10, 2008 | 03:57 PM
Texas Outlaw
Not a liberal...
Can't edit the above post. Now that I think about it I see your point. Still, I don't have any problems and never have. My truck runs like a scalded ape and I don't have any low boost symptoms like high EGTs or lack of power so I will leave mine right where it is.
Old Mar 10, 2008 | 04:59 PM
bdrummonds's Avatar
bdrummonds
On the flip side of all this, it just goes to show you how unneccesary the AIH is (in the lower 48). the AIH is in the direct path of the colder charge air after the IC. Why heat up the air you've just cooled down. (I do realize that you folks in Canada/ Alaska need the AIH, other wise the air would be supercooled and bring cylinder temps down)
shark1979
Feb 26, 2010 04:29 PM
johnsjsj
Nov 19, 2009 02:18 PM
wildstang
Oct 26, 2009 04:34 PM
kupaa
Feb 10, 2008 06:07 AM
wldcat65
Mar 8, 2006 07:21 AM
