Sponsored by: Real Truck
Proactive Ball Joint Maintenance
Old Mar 9, 2008 | 03:34 PM
dwilliamsceg's Avatar
dwilliamsceg
Is there anything that can be done to a F250 to help prevent the ball joints from wearing out at 60,000 (or so) miles?
Has anyone tapped the knuckles and installed zerk fittings, etc.?
Thanks.
Dave.
Old Mar 9, 2008 | 03:45 PM
cartmanea's Avatar
cartmanea
I'd just wait and replace them with greasable Moog ball joints when the time comes.
Old Mar 9, 2008 | 08:48 PM
skoveng's Avatar
skoveng
That's it. Just wait and replace. If you have a dealer or shop do the work, make sure they install fittings in both the upper and lower joints. The upper one will need a 45 deg. fitting to get to it around the axle u-joint.
Old Mar 9, 2008 | 09:00 PM
mudmaker's Avatar
mudmaker
There is nothing saying they are going to go out around 60k. Some guys have issues some dont. I replaced my ball joints at 155k. Like has been said, Just run the factory ones until they need to be replaced and put a set of moogs in w/ zerks.
Old Mar 9, 2008 | 09:30 PM
clux's Avatar
clux
Yes I have read of guys drilling and tapping them for zerks. Don't know if it made them last a lot longer, but it's got to help.
Old Mar 9, 2008 | 09:33 PM
cartmanea's Avatar
cartmanea
Wouldn't this risk getting metal fragments or burrs in the joint?
Old Mar 9, 2008 | 09:35 PM
Budman1962's Avatar
Budman1962
Just use a grease injection needle. Jab the needle through the rubber and pump the grease in. Works for all joints that don't have zerks.
Budman
Old Mar 9, 2008 | 09:43 PM
ReAX's Avatar
ReAX
Mine are fine at 70k, most of that with 315's. The needle is my plan too, but I 've been to lazy to do it.
Old Mar 10, 2008 | 07:11 AM
350z's Avatar
350z
Arrow
After I drilled and tapped mine , I used a magnet from a drain plug to remove the small shavings .
Old Mar 10, 2008 | 10:17 PM
thedaddycat's Avatar
thedaddycat
I read a post about Moog QC going down and the poster used a different brand of ball joints. I can't recall what they were though... I think it started with an A
Old Mar 11, 2008 | 08:14 AM
bedwards's Avatar
bedwards
Drilled and tapped my lowers, but how do you do the uppers on a 4x4?
be
