Air Compressors?
Old Mar 9, 2008 | 09:20 AM
48' fordster's Avatar
48' fordster
Air Compressors?
Hey all, I am looking to get a new air compressor for my garage and I was just wondering what I should be looking at. I want it to be able to keep up with my air tools (impact, sander, ratchet, cut off wheel) I am just so sick and tired of having to sork for two minutes then wait for 5 untill it pressures up again. I need something fairly cheap because im going to be running hard lines through my garage and i dont have that big of a budget. So what would be a good compressor and a good max Psi for my needs.
I was looking at somthing like this, http://www.northerntool.com/webapp/w...1707_200311707
Would that be good?
Old Mar 9, 2008 | 01:33 PM
Duke78's Avatar
Duke78
I have the same one pretty much. What is your other compressor?
If you just run the 60gal you have shown you'll still be waiting if you use high CFM demanding tools, like a spray gun or sand blaster. DA and other tools will be a piece of cake. If you already have a compressor then use it aswell, gang them together.
That's what i did... I also ran a pretty elaborate black pipe system... Check mine out see what you think... My other compressor is a 2hp 20 gal...
http://rides.webshots.com/album/561942724qzMJHd
I got my compressor at home depot, it was $300 even. Just so you know. It has the same exact HP and CFM rating as the one you listed. Good luck.
Old Mar 9, 2008 | 08:08 PM
72f250CS's Avatar
72f250CS
DUKE, my question is why did you put the loop to the ceiling then down to the valves? does it help with moisture or something?
I'm looking to do something similar, but my tank will be out side.
Old Mar 10, 2008 | 07:44 AM
Duke78's Avatar
Duke78
You are right... www.tptools.com They have the setup outlined that i used. The physics of it is that when you compress air you heat it up and water vapor is carried in the air. As the air travels through the pipe it cools and drops the water, you want this too happen in the pipe so you should slope your pipe back to the tank. By using "risers", running the pipe up, you force the water out even more. My system has a main line, 3/4" black pipe, with an 18" riser to the ceiling. The pipe then goes down and TEE's to a ball valve drain and then to my tool drop, 1/2" black pipe. For the drop i ran another "riser" to kick the water out even more. Then to the water separator, regulator and .01um filter.
Pretty clean and dry by the time it gets to the tool. Drain your system ever time you use it, including the water separator and the tank *****.
I have been sandblasting a lot lately and i want to be able to paint, both require dry clean air.
Old Mar 10, 2008 | 04:15 PM
blue68f100's Avatar
blue68f100
For your air tool requirement, you need a compressor capable of delivering around 8 cfm @ 90 psi. The one you posted may be a little light, 13 @ 40psi. If you plan on spraying paint, you need one rated for at least 15 cfm if your going to use a HVLP gun.
Sledmamma
Jan 3, 2012 05:42 PM
IZZYAZ
Apr 10, 2009 10:46 PM
Neal 97 250
21
Sep 26, 2007 08:26 PM
preppypyro
Paint & Bodywork
21
Feb 12, 2006 05:34 PM
88grandmarquis
Garage & Workshop
16
Dec 26, 2005 03:58 PM
