Time to replace camshaft...
Old Mar 8, 2008 | 10:53 PM
Colo79Ford's Avatar
Colo79Ford
I am going to swap a camshaft / lifters / timing set in a friends truck this next week. I am trying to get an idea of how long it takes so i can get him a good estimate on labor $$$$...
If anyone here has swapped out a cam, and can let me know how long it took you, I would appreciate it!
Thanks.
Old Mar 9, 2008 | 12:22 PM
mark a.'s Avatar
mark a.
It depends on how it all goes and if you have help. Someone to clean and scrape gaskets & hand you tools will be very helpful. Lifters can be a real pain to get out sometimes. If it's some kind of performance cam you will need to check lifter preload. You may have to shim or change push rods to a different length.
If everything went relatively smooth & you have help, I'd guess around 5 hours.
Old Mar 9, 2008 | 03:40 PM
Colo79Ford's Avatar
Colo79Ford
YEah, i was thinking 5 hours on it. The truck is all stock and he wants just a stock cam put back in, so wont be too big of a deal. I just hope the lifters arent mushroomed on the bottom.
Old Mar 9, 2008 | 06:30 PM
Colo79Ford's Avatar
Colo79Ford
After going and looking at mine, finally, im going to try to have it done in 2 hours or so, ill see.. Didnt look like it should take more than a few hours.
