Oil leak?
Old Dec 3, 2001 | 11:33 PM
1ole4d's Avatar
1ole4d
Oil leak?
Ok...when I first got my truck oil used to leak out from behind the intake manifold and create a puddle of oil on the back of the engine. Well...I rebuilt the engine and installed all new gaskets. Even the valley pan for the intake. Well..it's doing it again. Is there any way to stop this leaking or is it just one of those characteristics of the Modified?
Please don't pull out in front of me! I can't afford to play "What's this?" with you or your car.
Old Dec 4, 2001 | 06:28 AM
Bill_Beyer's Avatar
Bill_Beyer
Oil leak?
Did you replace the oil pressure sending unit? They are notorious for leaking. I had a wicked oil leak from the back of my motor and as soon as I changed the sending unit it quit.
Old Dec 4, 2001 | 03:39 PM
beartracks's Avatar
beartracks
Oil leak?
I've found the same problem with an added line for an oil pressure gauge leaking at the "T" under the original sender. It can be tricky to get the manifold set and sealed without squeezing out the end seals.
Bear
Old Dec 4, 2001 | 09:39 PM
1ole4d's Avatar
1ole4d
Oil leak?
I replaced the OEM unit with an aftermarket oil pressure line for my gauge. I wrapped the fittings in Teflon tape when I installed the gauge but it still leaks. Arrgh!!!
Old Dec 5, 2001 | 10:04 PM
Franklin2's Avatar
Franklin2
Oil leak?
DrZoom
20
Dec 22, 2016 09:13 AM
syjl
Dec 5, 2016 01:48 PM
johnson2007
Apr 26, 2011 01:21 PM
hotstang
May 12, 2010 10:08 AM
keithw99
Jul 13, 2006 02:38 PM
