Headlights Stopped Working
Old Mar 23, 2008 | 10:31 AM
Sam_Fear's Avatar
Sam_Fear
Use a test light or a multi-meter. I have a cheap 10$ multi-meter - it's worth it for chasing down wiring problems, and you're likely to have more eventually. You could have checked that switch instead of buying one.
You can use any 12v bulb and spare wire. Headlight, dash bulb, brake light, etc. In a pinch I've just disconnected my turn signal and shoved 2 wires into the pin sockets before. Ground one, and use the other to find where the voltage stops, by checking at each connector. In your case, if the light comes on at the light side of the dimmer switch but not at the next connector down the line, then that section of wire has the short. (make sure the switch is on dim!) If it lights, try the next connector. If neither bright or dim worked, I would have started at the fuse block and worked, step by step, to the light, and then to the ground.
Often times the connectors themselves are corroded not only on the ends where they connect, but also where the wire is clamped to the connector. So sometimes when you find a shorted wire, all you need to do is replace the end, instead of running a new wire.
Hope this helps a little rather than confuse alot!
Old Mar 23, 2008 | 10:42 AM
BobbyFord's Avatar
BobbyFord
How about two burned out low beams? Run a test light to the headlamp plug.
Old Mar 23, 2008 | 09:20 PM
KILLER'S_60&66's Avatar
KILLER'S_60&66
Hey Bobby~
It was the two burnt out low beams I think. I do not have a spare one that has working low beams, but there is power to the lamp plug at the front and it is to both the green and red wires. Is the red wire the low beam? That seems to be what I have isolated it as so far... I also wonder if you guys could give me a few pointers to avoid this occuring again. I just replaced the set about 8 months ago and once of them was replaced about two months ago!! I am a bit nervouis about why this is happening! Thanks!
KILLER
Old Mar 23, 2008 | 10:15 PM
rbaker6336's Avatar
rbaker6336
KILLER
Were they by any chance GE lights?I have had it happen twice and both times were GE
Old Mar 23, 2008 | 11:10 PM
KILLER'S_60&66
No they were all sylvania lights. I am not sure what is going on! I will stay away from GE too for sure!
KILLER
Old Mar 23, 2008 | 11:32 PM
paul 64's Avatar
paul 64
check out all your frame and cab grounds and your alternator to make sure your not overcharging or getting a power spike that can blow bulbs
Old Mar 23, 2008 | 11:44 PM
KILLER'S_60&66
Paul~
How do I check my grounds (I mean, what do I look for?). Also, how can I test my alternator to ensure I am not spiking it to bust bulbs?
Thanks
KILLER
Old Mar 24, 2008 | 09:04 PM
paul 64's Avatar
paul 64
the gronds are easy to check make sure there all tight and maybe take them loose clean them with awire brush there should be one from the frame to engine to body the alternator is a little hader do you have a light or guage if you have a guage you can watch it close to see if it overcharges if not you can take it to a shop and have it checked i have a portable voltmeter ihook up as you drive it records the lowest and higest reading but its pretty pricey and not worth a one time deal if there is a local alternator shop they should be able to check it shouldnt cost mutch paul
Old Mar 25, 2008 | 04:46 PM
KILLER'S_60&66
Hey fellas~
It was the headlights both being burned out and I have hit another obstacle. In moving around of my parent's SUVs and my trucks, I have lost the two screws that hold my dimmer switch to the floor. I wondered if someone like numberdummy would know what the size of those screws were and their thread pattern. Thanks so much guys! You are an amazing resource!
KILLER
P.S. Paul, thanks for the helpful hints...I will let ya know what happens with the new set of lights
