Header?
Old Mar 8, 2008 | 12:39 PM
MER's Avatar
MER
Header?
What is the difference in the headers for the 2Wheel drive and the 4Wheel drive and will the 2Wheel drive fit the 4Wheel drive 300 I6? Thanks in advance
Old Mar 8, 2008 | 01:09 PM
Silver Streak's Avatar
Silver Streak
As far as anyone here has determined they are the same on the later model trucks. As long as you don't have anything 4x4 related sticking out the passenger's side of the trans you'll be fine.
Old Mar 8, 2008 | 04:52 PM
optikal illushun's Avatar
optikal illushun
80-95 2wd and 4wd will work. the older it gets tricky.
Old Mar 8, 2008 | 07:32 PM
1980FORD's Avatar
1980FORD
When I was comparing the two versions the only real difference I could find was the difference in primary tube diameter and flange thickness. I assume that the clearance issues are the same on a F150 as they are on the F250 (which is what you asked about in your other thread)? I have an old post that is called 2wd or 4wd header and got some good advice from other members if you can find it with the search function, which is not always the easiest thing to do!
Old Mar 8, 2008 | 09:20 PM
1980FORD's Avatar
1980FORD
Here is the thread
https://www.ford-trucks.com/forums/6...wd-header.html
Hope the info in it helps.
Old Mar 8, 2008 | 09:28 PM
MER's Avatar
MER
Thanks! The 2Wheel Drive headers seems to be alright for the 4Wheel drive ! That is a real good thread Thanks again.
hav24wheel
Oct 4, 2011 09:49 AM
agthomas2
13
Dec 3, 2010 09:46 PM
Fordworth
WTB - Parts & other
Nov 28, 2010 03:07 PM
nitro520
Mar 9, 2003 12:37 PM
nitro520
Mar 7, 2003 08:01 AM
