haha. sounds like mine with a 22k, 33k should be enough to trip the high pressure relief valve
Joe ,,
no disrespct intended ... I 've always thought what you gain at the bottom , you loose at the top...Not just with your mod , but which ever way its done ... If you are fooling the PCM ..the ICP increase just begins & ends in a different place ....Just a thought ...nothing to back it up ....
