Sponsored by: Real Truck
Coils or Leafs
Old Mar 7, 2008 | 01:07 PM
alz's Avatar
alz
Coils or Leafs
I'm interested in purchasing a used F250 CC shortbed 4x4.
Is there much difference in ride quality of the newer coil sprung frontend over the older leaf?
What year did they switch over, 05?
Old Mar 7, 2008 | 01:17 PM
cartmanea's Avatar
cartmanea
Coil springs ride softer and have a tighter turning radius. I'd get a newer one with coils if given the choice.
Old Mar 7, 2008 | 01:31 PM
alz's Avatar
alz
What year did coils come on? 05?
Old Mar 7, 2008 | 01:41 PM
ChrisA.'s Avatar
ChrisA.
Al, I think they switched in '05, I had a '03 F250 with the leaf springs and now have an'08 with the coils, the '03 didn't ride bad but you needed a mile to turn it around,the '08 does ride better and woo-hoo! I can make u-turns on city streets now! Look for the coils if possible,its one beefy front end! Chris
Old Mar 7, 2008 | 02:07 PM
DCSpecial's Avatar
DCSpecial
Yep 05 and newer have coils.
Old Mar 7, 2008 | 02:25 PM
elmo8641's Avatar
elmo8641
with coils comes "death woble". but they do ride alot better and turn sharper. i don't know if ford figured out the problem but there seems to be alot less threads about the death woble thing.
Old Mar 7, 2008 | 02:53 PM
7.3F250lovinIt's Avatar
7.3F250lovinIt
Yep...leafs take a country mile to turn.
Old Mar 7, 2008 | 03:21 PM
cartmanea's Avatar
cartmanea
Well, actually wheelbase makes a huge difference in turning radius too. My super cab short box turns way sharper than my dad's crew cab long box, both '03 with leaf springs.
Old Mar 7, 2008 | 06:36 PM
92f150I6's Avatar
92f150I6
Ride quality is subjective. The coil sprung trucks seem to have more of a floaty (AKA old 70's car) ride to me. The leafs seem to be a bit more stiff and have less body roll. The coil truck do turn a lot tighter for sure.
Old Mar 7, 2008 | 10:34 PM
GregsSD's Avatar
GregsSD
In 05 along with changing to coils, Ford put larger upgraded brakes on the superduties.
Old Mar 7, 2008 | 11:14 PM
biz4two's Avatar
biz4two
Arrow
I'll second that! My '03 SC SWB takes a lot to turn, but not near as much as my Dad's '01 CC SWB.
Either parking lots have gotten smaller...or they need to get bigger???!!!
biz
Old Mar 8, 2008 | 04:45 AM
alz's Avatar
alz
Thanks guys for the input.
Looks like I'll shop for 05 or newer.
Old Mar 8, 2008 | 11:09 AM
UP_There's Avatar
UP_There
You never said which engine option you are considering with this truck. There is a big difference in Diesels starting in 03. That year you can get either a 7.3L or a 6.0L. Pretty significant difference between the two engines! The V10 or 5.4 changed from a 2v to a 3v at some point....not sure of that, but I'm sure somebody will chime in.
Old Mar 8, 2008 | 03:32 PM
redford's Avatar
redford
FTE Leadership Emeritus
Power Stroke engines: 99-03 7.3L, 03-07 6.0L, 08+ 6.4L
Gas engine: 99-04 2V V-8 and V-10. 05+ 3V V-8 and V-10.
Automatic Transmissions: 99-04 4R100 on gas engines, 99-03 on 7.3L. 04+ on Power Strokes (6.0 and 6.4) and 05+ gas engines, 5R110W Torqshift.
Front Suspension: 99-04 Leaf Springs. 05+ coil springs
Brakes: 99-04 smaller disc brakes. 05+ larger disc brakes.
Old Mar 8, 2008 | 08:38 PM
alz's Avatar
alz
I'll probably go with the V10.
Was really just getting an idea about the coils vs leafs.
Thanks again.
