Sponsored by: Real Truck
%*$@*! Tranny!
Old Mar 6, 2008 | 09:19 PM
bigdummyford's Avatar
bigdummyford
%*$@*! Tranny!
How many of you guys who have had tranny failure have had it suddenly just quit? I had mine fail today at the first stop sign as I left work, no good. I limped it out to a tranny shop when after shutting it off and letting the crap in the filter settle back into the pan it'd drive about a mile or not then stop driving the truck. So the tranny shop says it'll be done for anywhere from 2000-2500 ish and ready to drive and I like the price cause then I don't have to do the work! what kinda prices have you all paid at a tranny shop for a rebuild? Anyone have suggestions on upgrades that I can suggest?
Old Mar 7, 2008 | 09:39 AM
woody367's Avatar
woody367
My shop charges $1200 with converter. I new a guy that works there and they did it for me for $950 with 2 year warrenty.
Old Mar 7, 2008 | 10:21 AM
wlihntr's Avatar
wlihntr
WOW.. thats quite cheap!!! a standard rebuild kit for the 4R100 is about $500.00 so your shop will R&R the trans, rebuild it, and put in a new converter for another $700.00...what shop is this???
Old Mar 7, 2008 | 12:04 PM
rbaker6336's Avatar
rbaker6336
ain't figured how they can do that,can't remember exact figures but the kit is about $400 the pump is over $300 a cheepo Dacco torque is about $400
Old Mar 7, 2008 | 12:20 PM
woody367's Avatar
woody367
Sorry guys I typed in the wrong price and didn't read before I posted it. They charge $2200 and I paid $1950 see what happens when your in a rush.
Old Mar 7, 2008 | 12:26 PM
mcprjmngr's Avatar
mcprjmngr
Had the 4R100 go out in my '99 PSD, $2100 included Billet torque converter, shift kit, etc.
Good Luck!
Old Mar 7, 2008 | 12:33 PM
rbaker6336's Avatar
rbaker6336
there are some upgrades to make the 4R100 very strong,but think if I was going that route would either get a BTS or John Wood transmission and not worry about it again
Old Mar 7, 2008 | 12:44 PM
rugermack's Avatar
rugermack
BTS is about $3800
Old Mar 7, 2008 | 03:42 PM
sflem849's Avatar
sflem849
Same here. Mine is going to John Wood Transmission when it dies. It may be cheaper to go to a regular shop, but two tranny's are also pretty expensive
At the very minimum I would have them put the TransGo Tugger shift kit in. If you do that you will not have to worry about a valve body. They are cheap IIRC. Like under $100.
Old Mar 7, 2008 | 10:13 PM
bigdummyford
the shop is...
it is Oliver Bros transmission in Copperas Cove, Tx. I was told they us a company that advises upgrades nationally based on failures and that I'd get all the suggested upgrades for 2500ish. I went and looked at the pan today and it looked like it had a mini donut around the magnetic drain. NOT GOOD
but its gonna get started on monday and I can't wait to have her back even at almost 4$ a gallon fuel
Old Mar 7, 2008 | 11:04 PM
That_Guy's Avatar
That_Guy
BTS uped the price the begining of the year, its now $4100.
I called them today since my trans its pretty close to done.
Old Mar 18, 2008 | 11:43 PM
SC Silent Sam SOFWW's Avatar
SC Silent Sam SOFWW
..WELL...aint had major trouble with my E4OD...YET, (1997 F-250HD 4X4 7.3 PowerStroke CrewCab w/E4OD)
But I can tell you -I'm expecting trouble ! (170,000 miles)
I tow a 7500lb travel trailer, and I have had "A LOT OF EXPERIENCE" sittin behind a big diesel engine--over the road "Big Rig"trucking
And I have NEVER seen such a sorry excuse for a transmission, mated to a diesel engine, As the E4OD.....
This is because diesels deliver the peak torque/horse power at very narrow rpm ranges,
And the E4OD simply has -to few- gears to qualify as a "towing" transmission....hard on the engine... and just plain a -killer- for the transmission !
The trans SHOULD be geared to split at no higher rpm range than about 400 rpm....between gears
Mine has a "split" range of about 600rpm (?) and into OD....way up to about 7-800 (?)
Perhaps someone has the actual rpm split's between gears, and can verify the actual numbers
Never the less....these trucks need a tranny that has a split range that requires about 6 speeds --7 speeds would be even better for "serious towing"
No wonder they have a bad reputation in the trucks that do any towing !
.tho ok for a "socer moms SUV"
For "THE PRICE", Im thinking of building a 70'-80's Ford CrewCab..with a 12 valve Cummins (w/up-grades) and a FULLER 7 SPEED OD Transmission....
Old Mar 19, 2008 | 09:36 AM
redford's Avatar
redford
FTE Leadership Emeritus
If you want to split the gears, get a Gear Vendor overdrive unit.
Old Mar 19, 2008 | 11:43 AM
SC Silent Sam SOFWW
Ya, That would work...not sure about the available "ratio's"....
Just seems like the mfg's would, engineer this stuff...called "Towing Pkg's" ...for the job they take your $$$ in the name of !
Rather than havin us find we need to invest several thousand -MORE $$$ to get it closer to right
I know it's been such a big issue that --Now-- 10-20 years in, they are ALL now useing at least 5 speeds...
And a few are out with Automatic.. 6 speeds, and a couple of 7 speeds that can handle considerable torque
(Automatics are good for us old guys with wore out legs and hips...from all those years of jammin gears-and operating equip..and stoppin bullets and flying steel..and nail gun accidents...an bar fights, and motorcycle mishaps, and plane crashes....and CowBoy accidents... an stuff !
Old Mar 19, 2008 | 12:35 PM
dkf's Avatar
dkf
$2200-$2500 isn't bad for a rebuilt 4R100 with shift kit, new converter and install. Get a quote from the stealership, that will make your jaw drop.
If you never want to buy another tranny again you could get one of these.
Diesel 4R100
http://www.factorytechtransmissions....PROD&ProdID=15
Gas 4R100
http://www.factorytechtransmissions....PROD&ProdID=16
