Missouri Chapter Join Chapter , Leader:77&79F250
Need help fixing car!
Old Mar 6, 2008 | 08:57 AM
pintoches's Avatar
pintoches
Quote:
<table border="0" cellpadding="4" cellspacing="0" width="100%"> <tbody><tr> <td class="alt2" style="border: 1px inset ;"> Originally Posted by pintoches
I'm now looking at a 2000 Ranger 4x2, auto, 3.0, 2dr,step side for $2000 what do you all think? Kelly Blue Book says $4200. but afraid mpg will be to low.
</td> </tr> </tbody></table>
Now I'm looking at a truck (not made by ford) but is a very good deal 2000 4x4 3door stepside, 5.3, 105xxx $6000
I was not able to get a loan for either Truck.
So now I must fix the car up a little to make the trip back to branson on a bi-weekly bases.
the car is a 94 cavalier 2.2 coupe 281,000 miles the last 60,000 on a salvage engine
the easy stuff I have under control new brakes, lower ball joint, struts.
But the problem is the car stutters and I have know clue why.
I have been told the car has studderd for atleast 80,000 miles on both the new and old engine, 20,000 of the miles I have driven it. The thing is, it does not do it all the time.
Things I have tried :
NEW PARTS: TPS, plugs, wires, all filters, Pvc,O2,
cleaned parts: intake throttle body, mass air flow,and more
I need thoughts
Old Mar 6, 2008 | 01:21 PM
tcbofade's Avatar
tcbofade
IAC valve.
(Well, it's a thought!!)
That's what caused my Escort to stumble, stutter, and hunt for a happy rpm range. It wasn't expensive ($20ish) or hard to do.
I'm not sure how to test 'em tho...
Old Mar 6, 2008 | 03:01 PM
pintoches's Avatar
pintoches
Originally Posted by tcbofade
IAC valve.
thanks Terry
I have cleaned the IAC it dose seem to be working most of the prop. is when moving at a constant throttle and speed. you can power right through the stutters.
Old Mar 6, 2008 | 06:30 PM
tcbofade's Avatar
tcbofade
Well, next up, I'd put a tester on the fuel line and see if you're getting constant pressure...a little variance will wreak havoc...after that, start chasing vacuum lines with a can of WD-40.
Old Mar 6, 2008 | 09:14 PM
ubereal2's Avatar
ubereal2
Red face
Do you feel the shutter when te car is in park, or is it when the car is in gear? If it's done this with two different engines, it sounds like a tranny issue.
In K.C. we had Cottman transmission shops, and would do a free diagnostic on a tranny. Could it be a tranny thing?
Bob
Old Mar 6, 2008 | 09:42 PM
pintoches's Avatar
pintoches
Bob
5 Speed tranny
Old Mar 7, 2008 | 06:55 AM
fellro86's Avatar
fellro86
GM's are notorious for fuel pump problems. the pressure test would be a good start. zotherwise, make sure there is no vacuum leaks. If there are no codes setting, you will have to try to find non-computer fixes. If you have access to a scan tool, you could watch the computer sensor signals to see if you can find a problem. Something else zI have seen is the coolant temp sensor fails intermittant, giving a false reading of the engine being cold, changing the fuel map. This many times does not set a code.
Old Mar 7, 2008 | 07:03 AM
97HD's Avatar
97HD
Distributor cap and rotor? I chased a cracked distributor cap on a 92' Grand-am for weeks, did about the same thing yours is doing. I guess it was getting an occasional moisture intrusion and causing it to misfire until it dried off again.
Old Mar 7, 2008 | 07:40 AM
fellro86's Avatar
fellro86
No cap on the 2.2, just coil packs. Could a coil, for that matter, if they reused the same from the old motor.
Old Mar 7, 2008 | 08:06 AM
97HD's Avatar
97HD
It could be the coil, but I wouldn't make the my fist part to replace. I'd go on with the fuel pressure checks the other posters suggested and then come back to the coil if all else fails. If it were the coil, I would expect it to be a more constant problem, or a complete failure.
Old Mar 7, 2008 | 09:51 AM
SR_Crewchief's Avatar
SR_Crewchief
Have you pulled the error codes?
Old Mar 7, 2008 | 10:19 AM
pintoches's Avatar
pintoches
at last check there was no codes, no light, I think the obdI setup if the light is not on there is no code but I will try to pull codes at work today.
Old Mar 7, 2008 | 05:18 PM
fellro86's Avatar
fellro86
GM's OBD I will store codes, even if the light is not on.
Old Mar 7, 2008 | 10:05 PM
pintoches's Avatar
pintoches
there are no codes
Old Mar 11, 2008 | 07:37 AM
SR_Crewchief
Hmmm. No codes...stutters at cruise but not under load.... I presume that it has an intank electric pump with a screen. The could be some debris in or on the pickup that is causing a fluctuation in fuel delivery.
