Missouri Chapter Join Chapter , Leader:77&79F250
Need help fixing car!
Old Mar 11, 2008 | 07:41 AM
tcbofade's Avatar
tcbofade
Were you able to find a Schraeder valve and check the fuel pressure?
Old Mar 11, 2008 | 09:14 AM
pintoches's Avatar
pintoches
Originally Posted by SR_Crewchief
Hmmm. No codes...stutters at cruise but not under load.... I presume that it has an intank electric pump with a screen. The could be some debris in or on the pickup that is causing a fluctuation in fuel delivery.
I was thinking the same thing cause it some time comes and gose when low on gas or I get gas
No have not, but have looked.
ON the way to work yesterday it ran great. other than dying at stop lights. so I got mad 105mph on highway in 4th no more dying.
changed the TPS again and tested the egr valve
my taxes where to be back by now. so just have to wate be fore I buy more parts
Old Mar 11, 2008 | 12:37 PM
tcbofade's Avatar
tcbofade
And you haven't found any vacuum leaks?
Old Mar 12, 2008 | 10:35 PM
pintoches's Avatar
pintoches
I test ed the coils last night they seem to be good
put the new brakes and rotors on to day
Old Mar 19, 2008 | 07:19 AM
tcbofade's Avatar
tcbofade
And?? Is it running any better yet?
Old Mar 19, 2008 | 08:51 AM
pintoches's Avatar
pintoches
I put the new ball jount on got rid of the shakes.
Thought i found the prob under the dash but no. she is back to the studding
looking to egr next
Old Mar 20, 2008 | 03:42 AM
Lefty64's Avatar
Lefty64
Still havent read if the car shutters when in neutral? what rpm ramge does it happen at or speed?
Old Mar 20, 2008 | 03:57 AM
Lefty64's Avatar
Lefty64
ooops sorry for the above , didnt see there was a 2nd page. I am going to throw this one out there and you might think I am crazy but here it goes.... Have you checked the motor mounts? I had one of these that did something similar and found that a motor mount was bad and putting the engine, trans and axle shafts in a bind causing a shutter feeling. I know it sounds like a reach but worth a shot!
David
Old Mar 20, 2008 | 07:17 AM
tcbofade's Avatar
tcbofade
David
Ruh roh....
Welcome to the MO chapter, and thanks for the idea!
Old Mar 20, 2008 | 11:12 AM
pintoches's Avatar
pintoches
David
That is some thing we are know looking in to.
I just got home from buying the egr valve. will post later
Old Mar 20, 2008 | 12:51 PM
Lefty64's Avatar
Lefty64
Just another thought, if the motor mounts are OK then could be a CV Joint problem, The CV will start wearing in one spot thus allowing the joint to become unbalanced when riding in that spot. The problem will go away when the joint flex (under load) and then come back when cruising. I cant see your problem being a engine performance problem but it will be a bear to figure out. More than likely will entale some trial and error.
Old Mar 20, 2008 | 03:09 PM
pintoches's Avatar
pintoches
LEFTY you bring up some good points THat i have thought about. because some thing like that would not have been changed with the eng swap. the cv axles do have som play up and down, left to right the problem seams less now with the new ball jount
changed the egr vavle today drove 100 miles since change, no studders, but even before the chance it would not studder for days so we wait and see!
Old Mar 21, 2008 | 04:40 AM
  #28
Lefty64's Avatar
Lefty64
When you changed the motor out did you drop the cradle out of the car? If so then you might want to check the cradle position, if the cradle position is off (such as not square with the car ) then the same thing could possibly happen. Hope this is helping and not confusing you.
Old Mar 21, 2008 | 09:40 AM
  #29
pintoches's Avatar
pintoches
I did not change the motor my buddy that i bought the car from did. i do know about the cradle. but he had the studders even before the engine swap.
Old Mar 22, 2008 | 10:57 AM
  #30
pintoches's Avatar
pintoches
Cross your fingers! but no studders since I changed the EGR vavle. but it has gone days on end before with out studders.
