head casting numbers
I am gonna find out my #'s on my 351C 2V heads tomarrow, but were on the head do I look for them?
I already know it is a 74, and it is a 2V, but mainly need to know the cc size.Also who knows how to decode them? I will repost after i check if someone wants to tell me what they mean. thanx alot guys
--Stormr
--Stormr
Some head castings are around the spark plug area.
429/460 for sure.
Some are in the oil galley of the head.
For the actual day >Look for these marks with number too.
ie: * 8B23 *
Dennis
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
429/460 for sure.
ie: * 8B23 *
Dennis
w/Explorer Pkge.
84 Volvo DL Wagon
stormr,
Casting ID codes for all 351C heads are located on the intake side, below the ports. Casting codes for all M-block (351M/400) heads are located on top of the head.
To see the ID codes on a 351C head, you must remove the intake manifold. To see the ID codes on an M-block head, you must remove the valve cover.
All 351C heads are identified externally by a "2" or "4" casting mark (representing 2V or 4V heads) on the top, upper corners of the cylinder head, just outside the valve cover. M-block cylinder heads have either no mark or an "M" mark in that location.
Chamber volume of 351C 2V heads is advertised at 76.2cc. Chamber volume for M-block heads is advertised at 78.4cc, but I have measured several M-block cylinder heads with different volumes.
I listed some M-block cylinder head chamber volumes I measured in this post:
https://www.ford-trucks.com/dcforum/DCForumID12/355.html
I have not measured 351C cylinder heads.
daves77crew
08-24-2015 03:17 PM
Kruse
13
11-30-2014 04:59 AM
saleen065
06-12-2008 01:26 PM
1956f100
15
06-13-2004 12:16 AM
