head casting numbers
Old Feb 7, 2002 | 02:09 AM
stormr's Avatar
stormr
I am gonna find out my #'s on my 351C 2V heads tomarrow, but were on the head do I look for them?
I already know it is a 74, and it is a 2V, but mainly need to know the cc size.Also who knows how to decode them? I will repost after i check if someone wants to tell me what they mean. thanx alot guys
--Stormr
Old Feb 7, 2002 | 09:33 AM
stryder's Avatar
stryder
[updated:LAST EDITED ON 07-Feb-02 AT 10:33 AM (EST)]The casting numbers are between valve springs, if I remember correctly.
Stryder
:-X11
Old Feb 7, 2002 | 11:51 AM
Mil1ion's Avatar
Mil1ion
Some head castings are around the spark plug area.
429/460 for sure.
Some are in the oil galley of the head.
For the actual day >Look for these marks with number too.
ie: * 8B23 *
Dennis
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Feb 7, 2002 | 12:14 PM
beartracks's Avatar
beartracks
I believe all the 2v "M" and Cleveland head are 78 to 82 cc. As I recall the casting number is under the head next to the exhast. I don't think you can see it without taking it off. Some of them may be under the valve cover.
Bear
Old Feb 7, 2002 | 01:46 PM
bubbaf250's Avatar
bubbaf250
Post head casting numbers
stormr,
Casting ID codes for all 351C heads are located on the intake side, below the ports. Casting codes for all M-block (351M/400) heads are located on top of the head.
To see the ID codes on a 351C head, you must remove the intake manifold. To see the ID codes on an M-block head, you must remove the valve cover.
All 351C heads are identified externally by a "2" or "4" casting mark (representing 2V or 4V heads) on the top, upper corners of the cylinder head, just outside the valve cover. M-block cylinder heads have either no mark or an "M" mark in that location.
Chamber volume of 351C 2V heads is advertised at 76.2cc. Chamber volume for M-block heads is advertised at 78.4cc, but I have measured several M-block cylinder heads with different volumes.
I listed some M-block cylinder head chamber volumes I measured in this post:
https://www.ford-trucks.com/dcforum/DCForumID12/355.html
I have not measured 351C cylinder heads.
Old Feb 8, 2002 | 10:41 AM
beartracks's Avatar
beartracks
Bubba's got a better memory than me. At least with the Alzhiemers you get to meet a lot of new people every day!
:-X23
Bear Tracks
Old Feb 8, 2002 | 07:24 PM
400m's Avatar
400m
daves77crew
Aug 24, 2015 03:17 PM
Kruse
13
Nov 30, 2014 04:59 AM
saleen065
Jun 12, 2008 01:26 PM
olered53
Apr 26, 2006 12:18 AM
1956f100
15
Jun 13, 2004 12:16 AM
